Split rim latch
bgarrett
Topic author - Posts: 12
- First Name: b
- Last Name: garrett
- * REQUIRED* Type and Year of Model Ts owned: 26 roadster pickup. 26 TT
Split rim latch
I can make the missing part but what does the pin look like that goes thru both parts of the latch?
Re: Split rim latch
That's a Canadian rim - I recall the pin looking like a door hinge pin with a head on one end.
Alan Long
- First Name: Alan
- Last Name: Long
Re: Split rim latch
I agree with Steve.
Just confirm that when the main wheel part is attached that the latch or Pin doesn’t hit the end of the wooden spoke or it’s Ferrell. Alan In Western Australia
bgarrett
- First Name: b
Re: Split rim latch
thank you guys
J1MGOLDEN
- Last Name: Golden
Re: Split rim latch
The missing piece is identical to the piece showing.
J1MGOLDEN
- Last Name: Golden
Re: Split rim latch
There is a special tool to go in those holes to collapse or expand the rim when changing the tire.
J1MGOLDEN
- Last Name: Golden
Re: Split rim latch
This photo shows the whole latch assembly.
Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Re: Split rim latch
I believe the notation with Jim's last picture answers my question......Are these Kelsey rims?
Were kelsey rims the only ones to use this latching mechanism?
Someone told me the Kelsey rims do not fit the Hayes wheels properly.
I had posted a request for kelsey rims in the wanted ads previously with no response.
Harry Lillo
Harry Lillo
Re: Split rim latch
Harry, I believe they are Kelsey rims. All of our Canadian sourced cars have Kelsey rims. Re interchangeabilty with Hayes wheels rims, I once bought a pair of 21" Hayes wire wheels, onto one of which was bolted a Ford rim. The outside land on that rim had jumped over the edge of the Hayes felloe, meaning the only way i could get that rim/tyre off was to cut it
FundyTides
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Re: Split rim latch
As Allan mentioned all Canadian built cars of this period used Kelsey Canada wheels/rims. I became painfully aware of this the first time I tried to rebuild a wheel on my 27 Canadian Touring, using reproduction spokes available from the normal T suppliers. After several failed attempts to press the wheel together using the new spokes, I realized that the new spokes were too long and had a different profile at the hub. I ended up getting my wheels rebuilt by Bill Callimer who did an excellent job making and installing the proper spokes. Your problem with the locking mechanism is not unusual and, as other have mentioned, is easily repaired by replicating the hinge type piece on the rim and a hinge pin or piece of steel rod in the appropriate size. I have done a few of my wheels this way and never had a problem. These Canadian cars always hold a few hidden surprises!
DickC
- First Name: Dick
- Last Name: Cruickshank
Re: Split rim latch
I guess it goes without saying but I will anyway, Kelsey rims must go on Kelsey wheels. Kelsey rims will not go on Hayes or some other wheels.
bgarrett
- First Name: b
Re: Split rim latch
My rim does not have the two big holes on the side as shown in J1M Goldens picture
Re: Split rim latch
Without the holes in the sides of the rim, you have something unusual. There were lots of rims without the holes, but I am unaware of any of these having that 'hinge type' joiner. Be aware that if you replace both sides of the 'hinge' joiner, the pin holding them together must be oriented so that it is entirely on one side of the joint. From your photo this is clearly shown in the piece that is still there. If you orient the pieces with the pin over the joint, you will not be able to fit/demount the tyres.
bgarrett
- First Name: b
Re: Split rim latch
Thank you, Allen, I will get a better picture of the hinge when I get back from the Petit Jean Swap Meet. Its badly deformed.
