E timer
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
E timer
Post by Don ellis » Sat Jun 25, 2022 2:34 pm
Hey Mike, can I run a E timer with a 20 volt drill battery?
John.Zibell
Last Name: Zibell
Re: I timer
Post by John.Zibell » Sat Jun 25, 2022 2:39 pm
Probably better to contact Mike via direct e-mail then let everyone here know the answer.
1926 Tudor
Re: I timer
Post by DanTreace » Sat Jun 25, 2022 3:10 pm
From Mike’s website
The I-Timer is 6-12v DC only.
Don ellis
First Name: Don
Last Name: Ellis
Re: I timer
Post by Don ellis » Sat Jun 25, 2022 3:54 pm
Well mines an e timer, I’ve had it so long I forgot which one it was.
Re: I timer
Post by DanTreace » Sat Jun 25, 2022 4:48 pm
Then here are the voltage requirements for the E-Timer.
Don ellis
First Name: Don
Last Name: Ellis
Re: I timer
Post by Don ellis » Sat Jun 25, 2022 7:54 pm
I was thinking of convenience, I always have charged dewalt batteries around. If it was safe to use I could just throw one in the car for a spare.
Re: I timer
Post by speedytinc » Sat Jun 25, 2022 11:58 pm
A local t guy used to run a 13 roadster on a makita 9.6v battery on 1 tour he made it 1/2 way, maybe 80 miles, but didnt bring a second to make it home. Thats a normal timer T.
MKossor
Last Name: Kossor
Re: E timer
Post by MKossor » Tue Jun 28, 2022 2:47 pm
Sorry for the delayed reply, very busy lately. The E-Timer was designed to operate on 6V to 12VDC. It will accommodate battery charging to 14V maximum. Had an incident where an alternator VR went bad and the output voltage exceeded 15V that damaged the E-Timer.
The E-Timer operates very efficiently, a small 9V transistor radio battery powered it for almost an hour. It's difficult to say with certintity how long a particular battery will last without charging without additional information. A new 6V or 12V car battery will likely last a week of touring 3-4 hours a day (no head light usage) without recharging but I don't have solid data to back that up, perhaps someone else does. Certinally will last all day then can echarge over night to ease concerns.
Don ellis
First Name: Don
Last Name: Ellis
Re: E timer
Post by Don ellis » Tue Jun 28, 2022 3:23 pm
Thanks Mike
