New engine block?
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
New engine block?
Post by Chris Haynes » Fri Jul 01, 2022 2:53 pm
Now that retired engineer Terry Burtz has designed an improved Model A engine block with five main bearings, oversized insert bearings and full pressure oiling is there any reason the same can't be done for the T?
ModelTWoods
First Name: Terry
Last Name: Woods
Re: New engine block?
Post by ModelTWoods » Fri Jul 01, 2022 2:57 pm
I think its already been done by les Schubert in Canada.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Fri Jul 01, 2022 3:05 pm
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Fri Jul 01, 2022 3:37 pm
It doesn't appear that this project ever got into production.
Post by TXGOAT2 » Fri Jul 01, 2022 4:49 pm
That would be nice... 70 MPH T?
Post by speedytinc » Fri Jul 01, 2022 5:09 pm
You dont need all this extra investment to do 70, however your motor will last many more miles in theory.
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Fri Jul 01, 2022 5:32 pm
70 MPH at a high idle in high gear....
Kerry
Last Name: van Ekeren
Post by Kerry » Fri Jul 01, 2022 6:56 pm
Harry, only if you mess with drive ratio's. :D
Post by TXGOAT2 » Fri Jul 01, 2022 10:43 pm
I don't know how long a stock driveline would survive 70 MPH, but a 5 bearing engine with a counterweighted crank making about 45 HP could push most Ts to 70 or beyond with no durability issues.
Last Name: Wrenn
Post by TWrenn » Sat Jul 02, 2022 8:58 pm
Just don't forget about STOPPING that 70 mph T!! And what about those old dry spokes spinning twice as fast as they were probably designed for? Don't forget to check and update your life and liability insurance too!! :lol:
Post by John kuehn » Sat Jul 02, 2022 9:51 pm
Running 70 in a T on a stock front end and Rocky Mountain brakes with wood wheels doesn’t sound safe to me unless I said “I ain’t scairt” which I won’t say or do. Just my opinion. Nice idea for some I’m sure.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Jul 02, 2022 10:47 pm
Really Stock T engine, A carb, home made exhaust, 3:1 in a Ruckstell, A-C brakes & A wire wheels. The best I can do is by the GPS is 69.9 mph.
It was on the freeway with almost no traffic.
Post by speedytinc » Sat Jul 02, 2022 11:06 pm
Thats respectable for a stock engine.
Add a high compression head, a cam & a little bigger intake valves & you'll pull those 3-1's better.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sun Jul 03, 2022 5:37 am
End result: a fast old car, but not a Model T ....
Post by TXGOAT2 » Sun Jul 03, 2022 7:18 am
A full-fendered T speedster.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Jul 03, 2022 6:15 pm
The high compression, Chaffin's cam, speedway manifold, Tillotson carb, A-K dissy with not yet built header engine is going in a speedster with a 10 tooth pinion & a Warford = 3:1 gear and it should pull that rather well. I'm not a fender fan even My 1919 firetruck only has 2. I have had over a thousand Kids in my firetruck think what that will do to the hobby if just 1% get into the hobby. But by some standards its not a T? It will do 60mph in Muncie over drive. (Period correct accessory) If we continue to bicker with each other about little stuff we will do to ourselves what the environmentalist's are trying to do to us. If all the automotive hobbies would get together we could make the NRA jealous.
