ZERK Caps?
Professor Fate
Topic author - Posts: 773
- Last Name: S
ZERK Caps?
I was thinking about making up a cap with a grease fitting for the steering bracket to be able to force the grease around the steering shaft and bushing.
Anybody try this before?
Last edited by Professor Fate on Fri Jul 08, 2022 11:05 pm, edited 2 times in total.
________________
**FATE**
**FATE**
- Last Name: Tannehill
- Board Member Since: 2002
Re: ZERK Caps?
That’s such a good idea that the vendors sell them if you don’t want to make one yourself.
- Last Name: House
Re: ZERK Caps?
Yes; I’ve made them for all my “cup grease” fittings on all my T s. Just takes 2 different tap sizes. I placed a full grease cup in a vice grip and turned down the cup all the way and only had 2” of grease stream. Then I pumped one grease gun pump into a zirk screwed into another grease cup and was rewarded with 7” stream of grease. Much more efficient.
Re: ZERK Caps?
They are a good idea.
I still enjoy filling the cup and screwing it down. Call me old fashioned.
Do what works for you.
Re: ZERK Caps?
A pot of red grease and a putty knife ...
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Professor Fate
- Last Name: S
Re: ZERK Caps?
I've been filling the open fitting and pushing the grease in with my thumb. Easy but takes too long. Got other stuff to get done most of the time.
...... and I know the vendors sell them..... I wanted to possibly make my own.
Last edited by Professor Fate on Fri Jul 08, 2022 10:14 pm, edited 1 time in total.
________________
**FATE**
**FATE**
Re: ZERK Caps?
I don't think I would want one on the steering box. One reason it would look very noticeable. The other is if you have too much grease in the steering box, it will bleed out and get on your lap.
Professor Fate
- Last Name: S
Re: ZERK Caps?
Sorry Norm, I meant the steering bracket at the frame, at the bottom of the shaft by the pitman arm. The bracket with the long brass bushing I just replaced....
I apologize
I apologize
- Attachments
- s-l400.jpg (42.69 KiB) Viewed 2114 times
- isteeringmages.jpeg (13.51 KiB) Viewed 2114 times
________________
**FATE**
**FATE**
Re: ZERK Caps?
"I've been filling the open fitting and pushing the grease in with my thumb". ////// I use a putty knife to fill the screw-on cap with grease, then I thread it back on the base and give it a turn or two or three as needed. The flat knife makes it easier to get the cap full of grease with little or no air pockets.
Re: ZERK Caps?
I put one in my U-joint grease cup. Larry pointed out that it's not original, but Arthur Itis overruled him.
Re: ZERK Caps?
Then there are these if you choose to replace press-in oilers with zerks
Professor Fate
- Last Name: S
Re: ZERK Caps?
Steve, 8 years ago I tried one of those in that exact spot. I found that I couldn't get the threads to start. So I never put it in. The old one got reinstalled. Too much "donkey" pain to be bothered at the time. Convenience became a project....Steve Jelf wrote: ↑Fri Jul 08, 2022 11:51 pmIMG_2814 copy.JPG
I put one in my U-joint grease cup. Larry pointed out that it's not original, but Arthur Itis overruled him.![]()
________________
**FATE**
**FATE**
