26_27 running board supports
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Fri Jul 22, 2022 10:35 pm
Replaced a running board supports I had removed to. Haul the T on a small trailer 50 years ago. I had 2 supports and noticed a difference in them. At the end under the running board one of them has 2 holes to attach the board to. The other one has the same 2 holes to attach the board but it has a 3rd hole about an inch from the outer hole. The support that was never removed has the 3 holes and the holes are on both ends of the support.
Was there a difference between 26 and 27? I do not believe these were ever changed as the 3 hole type were on the frame and body when I got it and. It had sat in a pasture for many years,
If needed I will try to post a picture but I am having a problem loading it from a tablet and will have to load the pictures into the desktop to do it. I am not one of those computer genius's.
Re: 26_27 running board supports
Post by Allan » Sat Jul 23, 2022 7:58 am
The three hole ones accommodate wider 26-7 running boards. Why they have the third hole to fit the narrow boards I cannot understand.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Sat Jul 23, 2022 9:01 am
When the 26 cars were made the 3 hole brackets replaced the 2 hole that were no longer made. To have replacement brackets for the 2 hole you would just cut off the outer hole of the 3 hole
Post by Allan » Tue Jul 26, 2022 9:36 pm
That makes sense Jim.
