Brass Zenith Carb
Scott Owens
Last Name: Owens
* REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab 1927 Coupe
Brass Zenith Carb
Post by Scott Owens » Tue Apr 16, 2019 10:15 pm
HI, I just picked up a brass Zenith Carb that has OS or 05 on the side. It is an updraft with a 1.415 air intake and a 1.625 opening going into the manifold. A serial number of 26708 on the side. It looks real clean and I think everything is there. Float, linkage and butterflies are all in good shape. Any idea what this fits? Would it make a good speedster carb? Thanks, Scott
StanHowe
First Name: Stan
Last Name: Howe
Re: Brass Zenith Carb
Post by StanHowe » Wed Apr 17, 2019 12:04 pm
O is the design, 5 is the size.
Should be a pretty good speedster carb.
