Elastic stop nuts
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
Elastic stop nuts
Post by Emeraude » Wed Jul 27, 2022 9:33 am
While working on my t over the years where I removed bolts I would replace the nuts with elastic stop nut ( not one subject to rotation). I also spent many years working on aircraft and stop nuts are used almost in all applications.
Would Henry used castle nuts if stop nutswhere available then?
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Re: Elastic stop nuts
Post by Professor Fate » Wed Jul 27, 2022 10:15 am
"Would Henry use castle nuts if stop nutswhere available then?"
Maybe only if it was cost effective and/or labor saving?
Wouldn't the labor time spent installing a cotter pin being removed by using a nylon stop nut be appealing to Ford back then...?
My '23 is nut for nut, bolt for bolt as it came from HF. But my '26 speedy has modern hardware. I used nylon stop nuts on body bolts, steering column at the firewall, steering bracket, battery box to name a few. It ended up being a mix of old and new.
Last edited by Professor Fate on Wed Jul 27, 2022 10:25 am, edited 2 times in total.
________________
**FATE**
John Codman
Last Name: Codman
Post by John Codman » Wed Jul 27, 2022 10:23 am
I don't use stop nuts (I call them self-locking nuts) on my T, but I do use them extensively on my hot rod. In aircraft applications they should be a one-use item, so over time they are more expensive then reusable castle nuts.
The one exception to the no self-locking nuts in my T is one pivot bolt in the top supports. A lockwasher probably wouldn't work so it appears that a previous owner used a lock nut where (I suspect) a castle nut and cotter pin was originally used.
