1911 Touring Rands Hinge to Frame Placement
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Mon Aug 08, 2022 12:10 pm
Could someone send me pictures of the Rands Hinge mounting to the windshield frame from the back/inside side showing the hinge to upper and lower frame location. Also, the centerline location dementions of the mounting holes (from the flat of the frame). I am using a reproduction frame with original Rands hinges and I guess I have one shot at getting the hole and hinge to frame location correct. Any help would be appreciated. email: astein.pls@gmail.com
Re: 1911 Touring Rands Hinge to Frame Placement
Post by Rich Eagle » Mon Aug 08, 2022 10:11 pm
Does this picture from Royce help or is '11 totally different?
http://www.mtfca.com/discus/messages/80 ... 1242320404
or maybe this by Garnet?
http://www.mtfca.com/discus/messages/25 ... 1333701125
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Mon Aug 08, 2022 11:52 pm
Rands hinges
BigAl
First Name: Alan
Last Name: Stein
Post by BigAl » Tue Aug 09, 2022 1:00 pm
Thank you everyone who responded with pictures. The detail helps immensely on the assembly of the hinges to the frame.
