Oil
Myxr6turbo
First Name: Shawn
Last Name: Barnard
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Oil
Post by Myxr6turbo » Thu Aug 18, 2022 12:52 am
I know its probably been asked a million times, but what oil do I put in a 1926 Model T? The engine is all original except for the valves. Can I use oil from my local auto shop?
Thanks,
Re: Oil
Post by Norman Kling » Thu Aug 18, 2022 1:03 am
You are right. It has as many opinions as there are Model T's :lol: I use Valvoline non detergent 10W30 from Walmart. I change about every 600 miles and clean the screen above the transmission.
Especially if you don't know what type oil was used since the last time the engine was out and block and crankcase cleaned out, you might even change it more often because you might be dissolving old sludge from the engine. There is no pressurized oil system nor filter except for the after market screen over the transmission so all sludge and band debris will circulate with the oil. That is the reason for frequent changes. Because of this reason, it is a waste of money to use synthetic oil, which has been designed for long intervals between changes in modern full flow filters.
Re: Oil
Post by Steve Jelf » Thu Aug 18, 2022 1:04 am
Yes, it's an eternal question, but you have to ask if you don't know. :)
https://dauntlessgeezer.com/DG103.html
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Re: Oil
Post by Myxr6turbo » Thu Aug 18, 2022 1:46 am
That was a good read.
I pulled the engine down and cleaned everything so all good there.
Re: Oil
Post by TRDxB2 » Thu Aug 18, 2022 1:48 am
Its best to google it to see all the past opinions, reasoning for this or that and other things to do if you haven't or don't know when the oil was last changed. Use the Forum as a book
search using this oil mtfca.com
or https://www.google.com/search?client=fi ... =oil+mtfca
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Re: Oil
Post by Myxr6turbo » Thu Aug 18, 2022 2:45 am
I found this chart so I think 10W30 for Australian conditions should be fine. :roll:
https://mtfca.com/phpBB3/download/file. ... &mode=view
Last Name: van Ekeren
Re: Oil
Post by Kerry » Thu Aug 18, 2022 5:35 am
Shawn, most of the time that Autobarn, Super cheap or Repco have oil on special It's 15-30 or 15-40 that's perfect for a T in Australia for a good condition engine. Summer time can even use 20-50 and change the oil often.
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Re: Oil
Post by Myxr6turbo » Thu Aug 18, 2022 5:59 am
Just saw autobarn have 25% off. Does it matter if it's full synthetic?
Re: Oil
Post by Kerry » Thu Aug 18, 2022 6:34 am
Myself I don't use synthetic in a T for the reason that it has additives to reduce internal friction for which the T clutch pack works on friction to operate correctly and I think you will find it's not recommended for wet clutch motor cycles as well.
Alan Long
First Name: Alan
Last Name: Long
Re: Oil
Post by Alan Long » Thu Aug 18, 2022 6:44 am
I use Valvoline XLD 20/50 in our 3 Model T’s, Summer and Winter. I change it every 6 months, clean the transmission filter
and service the Roller Timer at the same time. Oil is cheap!
Alan In Western Australia
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Re: Oil
Post by Myxr6turbo » Thu Aug 18, 2022 7:00 am
I did a quick google. Who would have thought. Bunnings
https://www.bunnings.com.au/valvoline-5 ... l_p0066162
Re: Oil
Post by TXGOAT2 » Thu Aug 18, 2022 8:12 am
I run 10W30 full synthetic in my car with excellent results. I have Kevlar bands and a transmission cover strainer and magnet. I change the oil at 1500 to 2000 miles. I drive the car on mostly rural highways at 35 to 45 MPH in 70 F to 105 F weather. I do have an air filter.
John Codman
Last Name: Codman
Re: Oil
Post by John Codman » Thu Aug 18, 2022 11:52 am
I use the same 10W30 Rotella in my T as I do in my large-V8 hot rod. I use Rotella because it still has 1,200 parts per million of zinc. The zinc is not important to the T, but it is for the V8 with a bit of a performance cam and stiffer-then-stock valve springs. Since I keep the Rotella in stock, I might as well use it in the T. I use synthetic in just about everything else - including my John Deere garden tractor.
Re: Oil
Post by TRDxB2 » Thu Aug 18, 2022 3:06 pm
Thanks,
Yes, almost all places that sell engine oil will have what's appropriate. The oil is used to lubricate both the engine and transmission. Multi-viscosity oil is a best choice and the range of values is dependent on the ambient temperature you'll be driving in. Since the Model T has no oil filter, the service manual recommends oil changes every 500 miles regardless of the quality of oil. Some run longer intervals but that's their choice. Detergent vs non-detergent oil isn't really worthy of discussion if the oil is changed per the recommended interval. The oil should never contain any additive that is magnetic if you still have a magneto.
There are several Rotella 10w30 configurations: T4, T5, T6 and T. Now for the transmission that has what is referred to as wet clutch - there is an oil specification for that "JASO MA", "JASO MA2" or "JASO MA/MA2". This is important to some and not to other's
T4 (used be just T ) is a synthetic blend and the label has the "JASO MA/MA2" spec
T5 is also a synthetic blend but lacks the "JASO MA/MA2" spec (at least the label I read)
T6 is a fully synthetic blend and has the "JASO MA/MA2" spec
T4 or T6 price$ ? Regardless of the oil you choose you not mix brands or weights
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Oil
Post by Erik Johnson » Thu Aug 18, 2022 5:07 pm
When my dad first became involved in the antique car hobby in 1948 when he was 16 years old, he used the drained oil from his father's 1941 Cadillac for his Model Ts.
I know another fellow who was in the antique car hobby early-on who passed away last year at age 95. He told me that when he was a teenager, he drove a Model A Ford for regular transportation and the neighborhood garage let him take waste oil to run in his car.
Alan Long
First Name: Alan
Last Name: Long
Re: Oil
Post by Alan Long » Thu Aug 18, 2022 7:44 pm
Not so long ago when changing the oil on my 66 Mustang I was tempted to pour it into the T. It was clean and well filtered.
I decided not to take the risk. It would have been okay and the oil so much better than what was available back in the day.
I don’t think people were that fussy with their oil changing schedules then either. $30 for 5 litres is a good investment.
Just my opinion.
Quickm007
First Name: Mario
Last Name: Brossard
Re: Oil
Post by Quickm007 » Fri Aug 19, 2022 10:14 am
Thank you for the recall, always good to remember. Good for Canada either.
Super Mario Bross ;)
1911 Touring
1914 Speedster
Re: Oil
Post by TRDxB2 » Fri Aug 19, 2022 10:49 am
Since both T4, T5 & T6 are "synthetic" to some degree but only T6 is Fully Synthetic. Is that what you use?
Last Name: Wrenn
Re: Oil
Post by TWrenn » Fri Aug 19, 2022 7:53 pm
Right now you can get Rotella 15W40 online at WalMart for $15/gal. The 10W30 is twice that much. Don't know why. 15-40 works just fine.
To me, it's the best oil around.
Re: Oil
Post by Steve Jelf » Fri Aug 19, 2022 11:45 pm
Right now you can get Rotella 15W40 online at WalMart for $15/gal. The 10W30 is twice that much. Don't know why. 15-40 works just fine. To me, it's the best oil around.
I asked a well known engine/transmission rebuilder who has done a lot of Model T driving. 15W-40 was his choice. Another famously prolific T driver told me he uses Kendall 20W-50. I didn't think to ask why that particular brand.
Re: Oil
Post by TRDxB2 » Sat Aug 20, 2022 12:39 am
Based on the prices being mentioned for Rotella, regardless of weight 10W30 or 15W40, choose Rotella T4 since it meets the "JASO MA", "JASO MA2" or "JASO MA/MA2" specification.
Last Name: Wrenn
Re: Oil
Post by TWrenn » Sat Aug 20, 2022 8:16 am
[/quote Kendall is actually a very good oil. Used by a lot of race car drivers. A local race engine shop ways recommended it and used it in his race cars.
