AC Brakes thick washer location?
Bob in Texas
First Name: Bobby
Last Name: Wright
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
Post by Bob in Texas » Fri Sep 02, 2022 7:05 pm
I am installing set of new production AC Brakes on small drum rear axle. Kit came with a special think washer. I can't figure out where that washer goes. Any help out there?
Seems I remember it was spacer to keep the casting from breaking on rear backing plates other than very early axles.
I don't have any instructions I can find.
Thanks for any help.
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
First Name: craig
Last Name: leach
Re: AC Brakes thick washer location?
Post by Craig Leach » Sat Sep 03, 2022 2:52 am
I don't have the same A-C brakes as you have but I would look to see if the washer is needed to make the brake line up with the drum at one of the mounting bolts. I also saw a washer at the pivot point of the shoes in one pic. Alignment with the drum is critical to good braking. Craig.
Last Name: Strange
Post by CudaMan » Sat Sep 03, 2022 7:44 am
Try calling Larry Sidmore, the maker of the brakes, and ask. :)
https://mtfca.com/phpBB3/viewtopic.php?t=18722
Bob in Texas
First Name: Bobby
Last Name: Wright
Post by Bob in Texas » Sat Sep 03, 2022 8:23 pm
I did talk with Larry Sidmore and got it figured out.
