Float shellac?
hull 433
First Name: Stan
Last Name: Gadson
Float shellac?
Post by hull 433 » Sun Aug 28, 2022 2:53 pm
Does anyone have a recommendation for float shellac? I'd like to coat the cork float on my Holley G before its installed. I've heard of Indian Head gasket shellac, is there is a float shellac?
Last Name: Strange
Re: Float shellac?
Post by CudaMan » Sun Aug 28, 2022 4:03 pm
The alcohol in modern fuels will dissolve old-time shellac.
Use model airplane clear "hot fuel proof dope" instead. Model airplane fuel is a mixture of methanol and nitromethane and the dope is designed to be impervious to it.
Been Here Before
First Name: George John
Last Name: Drobnock
Re: Float shellac?
Post by Been Here Before » Sun Aug 28, 2022 4:08 pm
See Fahnestock, The Model T Ford Owner. It is a period book with some usable advise on cork floats.
Example to coat a cork float make a mixture of glue, glycerine, and water.
Or, See: https://groups.google.com/g/rec.aviatio ... TxzefcTW9s Suggestions are : used "Indian Head" gasket shellac, or hobby store and get 'hot fuel proof clear dope"
Who knows there may be other suggestions.
otrcman
First Name: Dick
Last Name: Fischer
Re: Float shellac?
Post by otrcman » Sun Aug 28, 2022 6:00 pm
Unfortunately, "model airplane hot fuel proof" dope is a thing of the past. As a long time model builder, I can remember when butyrate dope was truly hot fuel proof. But no more; the most you can hope for is to be able to resist a quick splash of fuel and an equally quick wipe with a clean, dry rag.
Today, most of my modeler friends cover their planes with a heat shrinkable pre-colored mylar material. The ones who still paint their models (like me) use a product called Klass Kote It's a two-part mix paint that resists all the model airplane fuels that I'm aware of. I have no idea whether it would adhere to a cork float. Klass Kote may even dissolve floats for all I know.
Sorry, I don't have any other substitutes to suggest.
Dick
Corey Walker
First Name: Corey
Last Name: Walker
Re: Float shellac?
Post by Corey Walker » Sun Aug 28, 2022 6:11 pm
You can coat it with PVC pipe glue. I use blue because that’s what I buy for plumbing but the clear probably works as well.
Last Name: Strange
Re: Float shellac?
Post by CudaMan » Sun Aug 28, 2022 6:16 pm
Old bottles of hot fuel proof dope are sold on Ebay, that's where I got mine. :)
Re: Float shellac?
Post by speedytinc » Sun Aug 28, 2022 7:49 pm
I have been using "line-a tank". Gas tank liner. Comes with a green & white label.
otrcman
First Name: Dick
Last Name: Fischer
Re: Float shellac?
Post by otrcman » Sun Aug 28, 2022 8:14 pm
Mark S wrote:
"Old bottles of hot fuel proof dope are sold on Ebay, that's where I got mine. :)"
Dick writes: " I never thought of that Mark. Good idea. That Klass Kote costs more than liquified diamonds."
DF
hull 433
First Name: Stan
Last Name: Gadson
Re: Float shellac?
Post by hull 433 » Sun Aug 28, 2022 8:52 pm
Thanks for the suggestions! I'll check them up. I've got a stalwart old cork float that I'd like to see go a few more miles.
There used to be a model airplane shop near here, but it closed last year.
Re: Float shellac?
Post by Allan » Mon Aug 29, 2022 2:59 am
I use shellac, harvested from a burnt roadside yakka plant on Kangaroo Island. The shellac occurs at the base of the razor sharp fronds of the bush. When the fronds are burnt off, the stubs and the shellac car be salvaged from the trunk.
During the First World War thousands of acres of native yakka plants were razed to get high quality shellac for use in munitions. It was hot, dusty, filthy work harvesting the shellac, and is responsible for the colloquialism 'hard yakka', applied to any physically demanding task.
I simply toss some of my harvest into a can and add methylated spirits to dissolve the shellac. The liquid is poured off, leaving behind the dirt, ash and any vegetable matter. If the mixture dries out, I just add some more metho. Floats I dip three or four times and that is it. It goes to say that I never use alcohol adulterated fuel in my T's. That's easy down under.
KimDobbins
First Name: Kim
Last Name: Dobbins
Re: Float shellac?
Post by KimDobbins » Thu Sep 01, 2022 6:25 pm
I made this new cork float for a 1912 Holley and sealed it with Red Koat tank sealer. Claims to be alcohol and additive resistant.
hull 433
First Name: Stan
Last Name: Gadson
Re: Float shellac?
Post by hull 433 » Fri Sep 02, 2022 9:31 pm
Hi Kim, thanks for the recommendation, I'll look into that.
