MUNCIE Gearbox Transmission Manual & Shift Pattern 3 speed with reverse
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Post by StevenS » Fri Sep 09, 2022 9:04 pm
This is from my files and notes on my Muncie gearbox / transmission which is a 3 speed (low, direct, overdrive) with reverse. Here is the information gathered up and in one place. One of the pictures is of the gear shift knob I cut the shift pattern with a Dremel tool. Instead of numbers I drilled one hole for first, two holes for second, and three holes for third, that way I can feel the shift knob and know where the gears are without looking. Sort of reverse brail.
Also on the gear shift pattern the number of forward gears and reverse gears is because I also have a Ruckstell 2 speed rearend.
Muncie Gear Shift Transmission Manual.pdf
(11.74 MiB) Downloaded 87 times
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
StevenS
First Name: Steven
Last Name: Sebaugh
Re: MUNCIE Gearbox Transmission Manual & Shift Pattern 3 speed with reverse
Post by StevenS » Fri Sep 09, 2022 9:05 pm
Sorry for the bad drawings, just from my notebook.
One of the pictures is of the gear shift knob I cut the gear shift pattern with a Dremel tool. Instead of numbers I drilled one hole for first, two holes for second, and three holes for third, that way I can feel the shift knob and know where the gears are without looking. Sort of reverse brail.
MORE INFORMATION
viewtopic.php?t=25862
1924 Model TT Truck
