bone yard find
andy2794
First Name: Andy
Last Name: Apjok
bone yard find
Post by andy2794 » Mon Oct 17, 2022 2:51 pm
I found this steering wheel assembly in a bone yard, does anyone know what it will fit? What it is worth? Anyone interested in it? It has been outside in the weather for years, do not know how long. It is a little over 4' long and a 17" steering wheel and wires coming out the bottom. It is located near Pittsburgh, PA.
Tadpole
First Name: Tad
Last Name: Glahn
Re: bone yard find
Post by Tadpole » Mon Oct 17, 2022 3:10 pm
Henry's lady and one of Edsel's greatest triumphs!
Re: bone yard find
Post by TRDxB2 » Mon Oct 17, 2022 3:14 pm
Its a Model A. Years? I think the steering box is what people are after
Marshall V. Daut
First Name: Marshall
Last Name: Daut
Re: bone yard find
Post by Marshall V. Daut » Mon Oct 17, 2022 3:34 pm
It's a 1930-31 Model A two-tooth steering column, a big improvement when this design came out in mid-1929 to replace the virtually wear non-adjustable 1928-29 seven-tooth gear box.
Marshall
Re: bone yard find
Post by Norman Kling » Mon Oct 17, 2022 4:14 pm
The steering wheel and shaft and gear box are a 30-31 Model A, however, the light switch at the bottom end is something else. Maybe some sort of replacement switch?
Re: bone yard find
Post by TXGOAT2 » Mon Oct 17, 2022 5:26 pm
Light switch looks stock to me. The switches often filled with grease and became "touchy". The column assembly is rebuildable, and may only need cleaning and rewiring. Parts are available.
