From what I could find, seems this assembly was only used for 6 months in 1926, then they went back to the shorter hub and the later style of bracket, with a flanged eccentric and an eccentric plate.
The only thing I'm not real clear on is the longer hub vs the shorter one...every one of the early 26's I've seen has the shorter one, but I suppose they may have changed out the longer one for the shorter one when they got a thicker radiator...anyhoo, let me know if this one is correct or not, thanks.
***1926 Fan Assembly (Early)***
VowellArt
Topic author - Posts: 584
- First Name: Martynn
- Last Name: Vowell
- Board Member Since: 2012
Fun never quits!
Re: ***1926 Fan Assembly (Early)***
I believe the longer fan hub was used when Ford introduced the 2 row radiator thus placing the fan closer to the core - not sure when that happened but I can check my parts lists.
VowellArt
- Last Name: Vowell
I believe that this is the correct dates.
Let me know if I've got them wrong.
Fun never quits!
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
Glad I was able to supply you with photos Brother Mart.
