crankshaft dimensions for regrind
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Mon Nov 07, 2022 3:20 pm
I am in need of the rework dimensions for a crankshaft rework or regrind.
What is the minimum diameter I can get by on the block Journals
and also what is the minimum diameter I can go to on the connecting rod journals.
I do not want to spend unnecessary time and money and find out I have a mail box
post.
Thank you
Johnr
Kerry
Last Name: van Ekeren
Re: crankshaft dimensions for regrind
Post by Kerry » Mon Nov 07, 2022 3:39 pm
.040" grind is what I max out the crank at although I did come across a crank that had been ground 60 thou and had done many years of hard driving before it broke.
Post by Jerry VanOoteghem » Mon Nov 07, 2022 4:15 pm
How much do you anticipate needing to remove? Unless it's heavily rust pitted, or it's been ground a few times already, it's hard to imagine having to get too extreme.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Mon Nov 07, 2022 4:26 pm
You also need to make sure you maintain an adequate radius. If the place you take the crankshaft to mostly does modern cranks they may not be aware of this.
J and M Machine
Last Name: Gulbankian
Post by J and M Machine » Mon Nov 07, 2022 5:39 pm
We typically stop at .030" under.
Don't forget to have the crankshaft crack inspected with wet mag "magnaflux"
Also make the shop aware they have to touch off the crank flange surface.
Post by Mark Gregush » Mon Nov 07, 2022 7:16 pm
While rods are easier to go with .010, .020, .030 or even .040 so you can buy off the shelf replacements if needed, I go with only having the mains done to clean up (all three ending up the same diameter) with 1/8" radiuses, taking off only as needed. Most can be adjusted to whatever size is needed.
Post by RajoRacer » Mon Nov 07, 2022 7:47 pm
On the same subject - Mark: have you used Crankshaft City down your way ? I have a dozen EE cranks I'd like to do something with !
Post by Mark Gregush » Mon Nov 07, 2022 10:16 pm
RE Crankshaft city, yes that is where mine got done. They did an ok job, not bad re the turn around. Because of delays, have not even looked at the crank I had them do for over 4 months. :(
