correct capacitor for coils
Don ellis
Topic author - Posts: 389
- First Name: Don
- Last Name: Ellis
The Tarheel T's model T club just purchased a ECCT from Mike Kossor, We are looking for the correct capacitor because of the forty or so coils I have all of them are in need.I know we can order from suppliers but we need bulk. This is a great tool and will be a huge asset to the club. Thanks
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Don ellis
- First Name: Don
- Last Name: Ellis
Re: correct capacitor for coils
Ah, just found an old post from Ron Patterson. Answers the question
Adam
- First Name: Adam
- Last Name: Doleshal
I use the specific orange drop capacitor that has been recommended by the Original Coilman, Ron (coilman) Patterson I believe that Fun Projects & Langs started having their own capacitors custom manufactured by another source several years ago and they are good too. I buy my capacitors wholesale in bulk and the usual wholesale point is over 1,000 pieces. At swap meets, etc, I sell 4 for $8, and bags of 100 for $175. Let me know if you want some. If you want a bag of 100, I might be able to set you up with a deal on 100 points too. Send me an email. Thanks.
MKossor
- First Name: Mike
- Last Name: Kossor
Don, The ECCT capacitor capacitor test is very sensitive so a couple comments on interpreting the test results:
The most important parameter of the capacitor test is the capacitor Value, typically 0.47uF but this can vary by +/-20% Capacitor value measuring less than 0.33 uf should be replaced to avoid excessive point contact arcing and ware. Coil points with insufficient capacitor value may result in a bright blue arc across the coil point contacts each time a spark is fired. The spark fired across the 1/4" spark gap may also appear weak or non-existent in extreme cases.
Capacitor test results displaying High capacitor value (0.56uF - 0.68uF) may not require the capacitor to be replaced even though the result may display Poor. That is because the capacitor test can be skewed by false leakage paths such fingers touching both point elements or primary winding to coil core leakage when the capacitor test is run. I have also experienced coils where the tops were painted with a carbon based black paint which was partially conductive electrically that made the capacitor value read high. The capacitor test results are classified as Poor because it deviates from the the nominal case but does not typically impact coil operation. Excessive capacitor leakage is readily apparent when the ECCT is used with the Advanced Features Software because the numeric value of Leakage Resistance is displayed. Leakage resistance as low as 100,000 Ohms will not cause any significant degradation in coil performance and does not warrant capacitor replacement. There should be minimal arcing across the point contacts and the spark fired across the 1/4" spark gap should be strong and consistent.
