D.S. spool
Mel King
Topic author - Posts: 96
- First Name: Melvin
- Last Name: King
D.S. spool
I have been reading about the bump & non-bump closed spools . What kind did the 15 have,bump or non- bump ? MEL.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: D.S. spool
Mel, The '15 pinion bearing spool had enclosed studs and the "bumps". I hope this helps,
Russ Furstnow
Russ Furstnow
