Brass speedometer
Randall strickland
Topic author - Posts: 158
- First Name: Randall
- Last Name: Strickland
Brass speedometer
Installing speedometer on a Freinds speedster and the inside cable is about one inch to short, is there a way to shorten housing?
Randall strickland
Re: Brass speedometer
Calble not a chain
Randall strickland
Tried to post picture of cable but will not post
The common SW steel housings ends are crimped on, so yes is possible to cut @ the edge of the crimped end, peel the outer cable out of the crimped end, force a rod into the end to uncrimp/expand & re crimp.
I wounld not do this unless the housing had damage near the end. (this issue did recently come up for me.)
Make a new longer cable or make an extended cable end.
- Last Name: Patrick
Let Russ Furstow do it.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
You can always use the original chain links. To adjust the length, simply add or subtract a link.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
The speedometer pictured is a "high speed" speedometer. It takes a 1:1 drive and not a 2.5:1 drive. It appears that the road gear and the swivel drive will not run the speedometer accurately. The cable should be around 48" long, and the length of the outer housing can be shortened. I hope this helps, Russ Furstnow
