Hayes wire wheel identification
Tracer
First Name: Andrew
Last Name: Webb
* REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
Post by Tracer » Mon Nov 14, 2022 9:48 pm
Hi All
I recall seeing a long time back and I cannot locate by searching, the chart that identifies the make of Hayes wire wheels. They are not all for Fords and the numbers on the back of the hub mean something ?
Cheers
Andrew a little lost down under.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Hayes wire wheel identification
Post by ThreePedalTapDancer » Mon Nov 14, 2022 10:14 pm
Post by Allan » Tue Nov 15, 2022 2:22 am
Andrew, i checked 10 front hubs I have for model T wheels. Two numbers were hidden by speedo drive gears. All 8 of the others show the number 1EA 111, for both 23" and 21" wheels. Hayes made wheels to fit Dodge and Nash cars and others I suggest. These would necessarily have needed a different casting to be machined to fit other makes of vehicle. They are most likely to have different casting numbers.
Tracer
First Name: Andrew
Last Name: Webb
Post by Tracer » Tue Nov 15, 2022 3:38 am
Thank you for all your help
