A Scope for Looking Into Dark Places
MikeSommers
Last Name: Sommers
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring
Post by MikeSommers » Tue Nov 15, 2022 11:06 am
A friend of mine was complaining about his colonoscopy, which got me to thinking... I have never been able to confirm that the babbitt thrust washers have been replaced in my differential.
Can someone recommend a good but inexpensive bore scope that works with an iPhone?
Thanks,
Mike
Re: A Scope for Looking Into Dark Places
Post by speedytinc » Tue Nov 15, 2022 11:16 am
See "removing hogs head or engine" post.
jab35
Last Name: Bartsch
Post by jab35 » Tue Nov 15, 2022 12:17 pm
In case the referenced rhoe post departs, https://depstech.com/products/endoscope ... iQQAvD_BwE
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Nov 15, 2022 12:24 pm
I have a similar self contained bore scope and use it all the time to look into places I can’t see. It is a must have tool.
Post by TRDxB2 » Tue Nov 15, 2022 1:02 pm
There are all kinds available. I purchased one for $10 included shipping from US seller for my lap top because of limited use - performed well came with some pick up attachments & a 90degree lens. Looked for brass spark plug nut my fried dropped into the combustion chamber to confirm it was there. Retrieval options being explored.
Most need something added to the camera probe to act like a wand to aim it
Not sure how any endoscope/borescope would work with grease or oil smear on the lens
The one mentioned above has some very desirable functions - taking a camera shot is a great plus. Not sure what the other controls do but if the left-right arrows cause the image to move LorR without moving the probe BUY IT!
Read how they connect carefully if they don't include their own display. Price/usage buyer be aware
Note the cost of less expensive ones & their options over the recommended one. recommended one is a good buy at its price
Did an eBay search for US sellers https://www.ebay.com/itm/385157400041?h ... R7DJusWPYQ
Here is one for an iPhone this Seller is in NJ https://www.ebay.com/itm/394117147133?_ ... %3A2047675
Post by Rich Eagle » Tue Nov 15, 2022 1:18 pm
If you are truly interested in looking into dark places you might try the Kalamity Dick thread. I cannot verify the thrust washers there but sometimes feel like I've had a colonoscopy after reading it. :o Often my own fault.
I hope you find what you need.
Post by speedytinc » Tue Nov 15, 2022 1:29 pm
BTW ebay has this camera @ 39.99. wow.
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Tue Nov 15, 2022 5:45 pm
Thanks,
Mike
Mike,
I bought this one for $40 on amazon. It seems to work well. The camera wire is crazy long, it takes photos and video. If you want to take photos and video, you need to provide an SD card, and you need a reader to pull them off. I just hope you don't get a photo like mine when you peer into a spark plug port:
It's 1080p but I wouldn't shoot home videos off of it.
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Fri Nov 18, 2022 1:30 am
My track record for going cheap, especially with electronics, is quite poor, so I dropped a few Benjamins on a Vividia Ablescope with a long flexible probe, steerable camera with an integral light, and the ability to wirelessly view and record stills and videos on a smartphone or tablet. Among many other things, I’ve used it to verify good cleaning and sealant coverage in all bays of my T’s gas tank, and to verify the bronze bushing on the right side of my rear axle (it just won’t go past the ring gear to look at the left side). I also need to periodically look at valves and seats in an overhead valve air-cooled aircraft engine.
Right Thrust Washer
Right Thrust Washer
Model T ring Gear
Model T ring Gear
‘24 Touring gas tank after POR15
Clean head bolt hole in model T block
Aircraft Exhaust Valve and Seat
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Post by HalSched » Fri Nov 18, 2022 1:43 am
I have one from Harbor Feight and it works ok
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Fri Nov 18, 2022 2:47 am
It may just be my luck, but if even if it is, NOTHING electrical from Harbor Freight goes home with me.
Miles
HalSched
First Name: Hal
Last Name: Schedler
Post by HalSched » Sat Nov 19, 2022 12:59 am
Try Northern Tool or NAPA.
