Coupe Glass Removal
hkraft1
First Name: Henry
Last Name: Kraft
* REQUIRED* Type and Year of Model Ts owned: 1923 Depot Hack (Martin Parry)
Coupe Glass Removal
Post by hkraft1 » Fri Nov 18, 2022 6:14 pm
Hello all,
I recently bought a 1925 Coupe and am starting to go through all that my car needs. I was able to get it running but I want to change out the glass for safety glass. I started working on removal the other day but although I removed what I thought to be the necessary parts of the door and windshield, the glass wouldn't budge. Is it just stuck, or is there something I'm missing? Thanks in advance.
Re: Coupe Glass Removal
Post by John kuehn » Fri Nov 18, 2022 9:47 pm
This earlier post may give you some basic ideas for removing Model T closed car glass removal. Good luck! it’s going take some gentle persuasion using a thin dry wall knife. There are other old car glass removal videos on the internet. Just type in Model T Coupe glass repair or removal as a general search on google and it will show some info and you tube videos.
https://www.mtfca.com/discus/messages/3 ... 1367240223
