Was wondering if anyone knows if Straw paint color was used for wire wheels on a 1926 Coupe.
If it was, would anyone knows what the color formula is to mix the paint. Also was the 26 body painted with
enamel or Acrylic Lacquer? Thanks.
Paint Color options for 1926 Coupe
BarnesvilleT
Topic author - Posts: 101
- First Name: William
- Last Name: Hallada
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Re: Paint Color options for 1926 Coupe
"WAS" ?BarnesvilleT wrote: ↑Mon Dec 19, 2022 12:03 pmWas wondering if anyone knows if Straw paint color was used for wire wheels on a 1926 Coupe.
Click on images to enlarge --
Not sure about these charts
- Last Name: Humble
The MTFCA Encyclopedia has a nice article on paint. 26-27 T's had bodies painted with pyroxylin paint, not enamel or lacquer. Pyroxylin paint did not stand up to time, nobody really knows what the actual colors are. There are best guesses for paint colors, and some paint codes are published in the encyclopedia, but again, they are a guess. Regarding colors of wire wheels for the coupe, all wire wheels installed at the factory were painted black. Dealers had wire wheels available for swapping or for sale, color choices were red, straw, green, and black.
This is a link to the MTFCA Encyclopedia section on paint. Think its the one that Jeff is referring to. You need to scroll down to see all that there is to read. https://www.mtfca.com/encyclo/P-R.htm
BarnesvilleT
Thanks guys. Great info. Appreciate it.
Kerry
- Last Name: van Ekeren
I don't know if the cars only come from the factory with only black wire wheels is correct, but the parts books give the options when buying them as, black, red, green, or straw color,
Parts books only list genuine Ford parts not dealership options.
