Why a notch?
Why a notch?
Post by Steve Jelf » Fri Nov 25, 2022 12:58 am
It must be there for a reason. What would that be?
JohnH
Last Name: Hunter
Board Member Since: 2002
Re: Why a notch?
Post by JohnH » Fri Nov 25, 2022 1:00 am
I always assumed it was to clear the key.
Alan Long
First Name: Alan
Last Name: Long
Re: Why a notch?
Post by Alan Long » Fri Nov 25, 2022 1:24 am
I’m with my Aussie Buddy from the other side of Australia but surely these were installed before the Key then the Hub?
Well that’s the way I’d do it?
Alan In Western Australia
Last Name: Wrenn
Re: Why a notch?
Post by TWrenn » Fri Nov 25, 2022 9:55 am
Yep. Key clearance.
Last Name: Wrenn
Re: Why a notch?
Post by TWrenn » Fri Nov 25, 2022 9:57 am
And there I go again...typing faster than my brain's in gear! :lol: I don't use those kind anymore, I like the "fancier" neoprene seals.
https://www.modeltford.com/item/2510N.aspx
Re: Why a notch?
Post by Original Smith » Fri Nov 25, 2022 10:16 am
Apparently, few have installed those retainer caps. They go on just fine with the key in place.
Re: Why a notch?
Post by Steve Jelf » Fri Nov 25, 2022 12:45 pm
Clearing the key was the only reason that occurred to me. So if that's the case there are two possible procedures that require the notch:
1 Install the washer, which has no notch, then the felt, which has no notch, then the key, and finally the cap, using the notch to get it past the key.
2 Remove the cap, using the notch to get it past the key, then remove the key, and then the felt, and then the washer.
How are those procedures better than installing or removing all three parts without the key in place?
Last Name: Hjortnaes
Re: Why a notch?
Post by DHort » Fri Nov 25, 2022 3:30 pm
I agree with Tim. Use the new style. The old style never wants to come off anyway.
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Why a notch?
Post by Pep C Strebeck » Fri Nov 25, 2022 6:39 pm
I used to agree with that statement, then I found the right tool for the job:
TFan
First Name: Jim
Last Name: Riedy
Re: Why a notch?
Post by TFan » Fri Nov 25, 2022 6:51 pm
Well La Dee Da Now I have a new tool to look for. Thanks Pep
RVA23T
Last Name: C
Re: Why a notch?
Post by RVA23T » Fri Nov 25, 2022 7:44 pm
It would be great to see the inside of the tool when possible.
Re: Why a notch?
Post by John kuehn » Fri Nov 25, 2022 7:49 pm
I never thought about what the notch was for. I saw the notch and figured it ought to be lined up with the key way. When removing the cover I tapped around the outside with a ball pain hammer. That would usually loosen it enough to get it to move and then spray behind it with WD40. It would then slip off.
I wooden if Stevens made a tool to use for it. They made one for most other T parts. If they did it’s not common. And if the one pictured or presumably a Stevens tool was found in a box of this and that at a swap meet it was probably passed over because it wasnt recognized.
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Why a notch?
Post by Pep C Strebeck » Fri Nov 25, 2022 8:16 pm
Not to hijack the thread (too much), I will add a link to a previous post with some more photos of the Dust Cap Puller.
viewtopic.php?f=2&t=9483&p=70586&hilit=cantrell#p70586
It was one of the axle tools made by Cantrell-Miller, I am fortunate enough to have all (both T and TT sleeve pullers) the tools shown, except the Hub Puller and Waste Puller that are pictured below.
RVA23T
Last Name: C
Re: Why a notch?
Post by RVA23T » Fri Nov 25, 2022 8:44 pm
Totally related if you ask me! Thanks for the extra info.
