How Tight Should These Nuts Be
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Tue Dec 06, 2022 9:05 pm
How tight should these nuts be? Is there recommended torque value?
1) Spring shackle nuts.
2) Nuts on bolts attaching front and rear springs to the frame.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Re: How Tight Should These Nuts Be
Post by BUSHMIKE » Tue Dec 06, 2022 9:15 pm
Hand Wrench tight and cotter.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Tue Dec 06, 2022 9:16 pm
snug, get all the weight of car and body then check them, they will draw up more then, do not have to he man them they are just there to hold all in place.
Last Name: Patrick
Post by jiminbartow » Tue Dec 06, 2022 9:36 pm
Does this help? I copied it from a Dec. 31, 2007 MTFCA thread. I believe I read on the forum that they did not use torques during the Model T era. Experienced mechanics just tightened by feel. Torque charts came about years later to show how tight certain sized bolts could be safely tightened before stripping or breaking. Jim Patrick
Post by Steve Jelf » Tue Dec 06, 2022 11:13 pm
"Tighten it until just before it breaks."
jab35
Last Name: Bartsch
Post by jab35 » Wed Dec 07, 2022 7:25 am
I agree with Mike on spring shackles, but spring to frame clamps, I tighten same torque as rear axle hub nuts. And cotter everything before you test drive. Spring to frame clamps may need retorquing after test drive. jb
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Wed Dec 07, 2022 8:13 am
I usually tighten most bolts until they break and then back them off a quarter turn. Art
Post by TXGOAT2 » Wed Dec 07, 2022 11:17 am
The spring to frame clamp nuts need to be tightened evenly in a cross pattern with the car sitting on level ground. After running a hundred miles or so, they will most likely need retightening. With old parts, caution must be used. For best results, have parts clean and springs lubricated.
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Dec 07, 2022 12:44 pm
Spring shackle nuts should be kept loose enough to allow movement.
jab35
Last Name: Bartsch
Post by jab35 » Thu Dec 08, 2022 11:49 am
Spring shackles as an assembly should be 'tight', if they bind on either the spring or perch that issue needs to be corrected in a way that permits full and tight assembly of the shackles. Shackle bolts left loose promote rapid wear of both the shackles and spring/perch bushings. jb
