cartridge pinion bearing
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Sun Apr 28, 2019 6:52 pm
Has anyone used or know about the cartridge pinion &thrust bearing for the D.S. for a 15? MEL.
Dennis Prince
Last Name: Prince
Re: cartridge pinion bearing
Post by Dennis Prince » Sun Apr 28, 2019 7:06 pm
Mel, I don't know if a 15 pinion bearing is different than a 26 but I have 2 26 T's that have a cartridge pinion bearing. The roadster has about 50,000 miles on it and the touring I just put it into. The roadster has been trouble free, I really like it or I wouldn't have put in a second one.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Sun Apr 28, 2019 10:33 pm
If your referring to the ones designed and first manufactured by Fun Projects your on a winner!
John advised me to purchase the standard version (without all the Shims) and in my opinion is a great upgrade
for your Differential. Install one of those, Brass Thrust Washers on the side carrier and the longer Axles and you will travel
trouble free for years and years. I also use Safety Hubs outboard also.
Alan
Post by Steve Jelf » Mon Apr 29, 2019 12:33 am
It's the FP bearing every time for me.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Mon Apr 29, 2019 9:31 am
Mel, I don't know if a 15 pinion bearing is different than a 26 . . .
There are great differences between 1915 and 1926 at that point. Will they make any difference to the FP conversion ?
"Get a horse !"
Post by Steve Jelf » Mon Apr 29, 2019 10:32 am
The difference between the 1915 and 1926 FP bearings is the housing that contains them. Both types are available. The other choice is between adjustable and non-adjustable. I was told by a VERY knowledgeable source that the adjustable type is for folks who think they need to have something to adjust, and that the non-adjustable version is quite adequate.
http://funprojects.com/search?querystr= ... rytype=all
Post by Original Smith » Mon Apr 29, 2019 10:39 am
I have genuine Ford pinion bearings in all of my cars, and they don't need to be modified to anything else. Ford had it right.
RGould1910
Last Name: Gould
Post by RGould1910 » Mon Apr 29, 2019 7:25 pm
Agree with using Ford parts if you can find nos or close roller bearings. Reason for making the new set up is the difficulty in finging decent bearings. I was lucky enough to find 4 nos ones years ago and have just now used them up on my cars.
