Kingston B-1 Gasifier
Jared27
First Name: Jared
Last Name: Antonino
Post by Jared27 » Thu Dec 15, 2022 12:24 am
Is there anyone out there that rebuilds Kingston B-1 Gasifier? I would like to try it instead of my Holley Vaporizer. Thanks Jared
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Re: Kingston B-1 Gasifier
Post by Jim, Sr. » Thu Dec 15, 2022 1:18 am
Call Tom Carnegie at The Antique Auto Ranch in Spokane. He knows all about the Kingston B=1 Gasifier. and uses them on his cars.
1922 Coupe , 1926 Touring
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Thu Dec 15, 2022 11:54 pm
Russ Potter restored one for me. I actually bought the carb from him and he rebuilt it. I don't have the car done that it will go on, so I can't give a performance review but from what I have read it is a very good carburetor.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Dec 16, 2022 12:30 am
I think I remembering reading a previous post here on the forum where someone said they ran much better than a Holley vaporizer.
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Mon Dec 19, 2022 6:07 pm
They're far superior to anything Holley ever built. The only reason Ford went more with the Holley's was because they were cheap to manufacture (and thus cost less, than a Kingston), plus they've no parts to wear out like that stupid heat transfer plate in the Holley's.
Don't know if you've seen these or not, I drew them for Jim Mahaffey who did an article on both the Gasifier and the Regenerator for the MTFCI publication. Also included throttle positioning for start up (with choke), car warm up, idle (which looks a lot alike car warm up, but isn't) and throttle open. You only need the extention neck (the piece between the carburetor and the manifold) if you're running it in an car with an under the seat tank, like a 25 Touring or earlier.....hope these help.
They are available here on the forum too, in the Gallery marked "VowellArt" under Carburetors.
Fun never quits!
