Stainless tie wire
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Stainless tie wire
Post by Dennis_Brown » Tue Dec 27, 2022 1:00 pm
What gauge is the stainless steel tie wire used on engine and transmission bolts? I know it must be dead soft for twisting and bending but i am wondering on the gauge or diameter.
Les Schubert
First Name: Les
Last Name: Schubert
Re: Stainless tie wire
Post by Les Schubert » Tue Dec 27, 2022 1:11 pm
I don’t use Stainless Steel wire. Just ordinary steel wire.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Dec 27, 2022 1:22 pm
I use .032 for smaller bolts, and .041 for larger.
Last Name: Juhl
Post by Oldav8tor » Tue Dec 27, 2022 1:47 pm
Same as Jeff - I also have a pair of aircraft safety wire twist pliers. If you're not likely to use them a lot, Harbor Freight makes a cheap pair for $10.
