Look for a thread on hand cranks
Last Name: Hatch
Post by Dan Hatch » Sun Jan 01, 2023 11:18 am
There was a thread years ago on how to make your hand crank stand up. Go ahead make the jokes but I can not find in. Anyone know where it is? Thanks Dan
Re: Look for a thread on hand cranks
Post by Steve Jelf » Sun Jan 01, 2023 11:43 am
I don't now where it is, but I know how I would do it. 1 weld a small piece of key stock on the front surface of the ratchet. 2 Cut a little notch in the rear end of the crank bushing. The crank spring keeps the key engaged in the notch until you push the crank in to start the car.
Last Name: Hatch
Post by Dan Hatch » Sun Jan 01, 2023 11:53 am
Thanks Steve.
Here is what I am talking about.
Post by TRDxB2 » Sun Jan 01, 2023 11:57 am
This is it by Thorlick » Mon Oct 14, 2019 1:36 am
https://mtfca.com/phpBB3/viewtopic.php?t=7524
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun Jan 01, 2023 12:05 pm
There were period accessory gadgets to effect that way to stow a crank. I use a farmer fix - a leather thong between headlamp irons with a small chunk of screen door spring. Cheap, effective, no welding or cutting - nothing to impair the crank if something fouls up.
Get a horse !
Post by John kuehn » Sun Jan 01, 2023 12:14 pm
Hadn’t that in a while. I wonder why Ford didn’t use that or something similar when T’s were being made.
Post by speedytinc » Sun Jan 01, 2023 12:36 pm
At least one vendor sells a brass license plat bracket with a fold down U that catchet the crank handle to hold it erect.
There were period accessories that took a pad lock. I have one, but havent put it on for fear of hitting something & taking out an $800 radiator.
I have seen several setups where the crank bushing has a notch & the crank handle is drilled & pinned as Steve describes.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Sun Jan 01, 2023 12:44 pm
Here is a close up of the hand crank on my speedster. I drilled and tapped the hand crank for a #10-32 bolt and cut a notch in the hand crank bushing that presses into the front of the pan. The hand crank spring keeps tension on the hand crank and holds it into the notch. I’ll post a better picture when I get back out to the garage.
Post by TRDxB2 » Sun Jan 01, 2023 1:06 pm
I believe I answered your question by providing the link to what your looking for above with pictures. Very easy method
Last Name: Hatch
Post by Dan Hatch » Sun Jan 01, 2023 1:39 pm
That was thread I was thinking about. Thanks
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Sun Jan 01, 2023 5:39 pm
Here are some more pictures of how I did mine.
Last Name: Hatch
Post by Dan Hatch » Sun Jan 01, 2023 7:07 pm
Thanks for posting pictures. Dan
Post by TRDxB2 » Sun Jan 01, 2023 7:43 pm
Don't think it has to be at 12 o'clock could do 3 or 9
