‘24 Roadster steering column bolts
BasketCase24
First Name: Jake
Last Name: Kluch
* REQUIRED* Type and Year of Model Ts owned: 1924 Roadster
Post by BasketCase24 » Fri May 03, 2019 8:18 pm
I did not notice during disassembly that the carriage bolts holding the steering column flange to the firewall have two different size heads. They all seem to fit everywhere. Anyone know how these should go, and if it matters?
Last Name: Strange
Re: ‘24 Roadster steering column bolts
Post by CudaMan » Fri May 03, 2019 8:24 pm
My guess is that you have two original bolts and two modern replacement carriage bolts. Check the heads of the bolts, if two of them have raised markings on them, those are the two modern replacements. The original Ford bolts had smooth heads.
Check with R.V. Anderson to see if he sells exact reproductions of the original bolts. :)
Post by Original Smith » Sat May 04, 2019 10:20 am
All Four of those bolts are the same. Many times when I run into a similar problem, I take an unknown bolt and put it in the lathe and make it the right size.
