How do you clean Champion X plugs?
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Fri Jan 13, 2023 9:07 pm
How do you take apart and clean plugs like the Champion X?
Re: How do you clean Champion X plugs?
Post by Steve Jelf » Fri Jan 13, 2023 11:55 pm
Put the collar in a vise and turn the base with a wrench. You can derust in Evaporust and finish with a wire brush wheel. Reassembling, you have to get it tight enough to stay together but not tight enough to crack the insulator. If the electrode ends are rounded you can flatten them with a little grinder, but be careful not to take off very much material.
https://dauntlessgeezer.com/DG95.html
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Fri Jan 13, 2023 11:56 pm
Post by TXGOAT2 » Sat Jan 14, 2023 8:43 am
I might use a wire brush on metal spark plug parts. I would never use a wire brush on any non-metal parts of a spark plug. I would use a small, fine, single cut file to re-shape electrodes, if necessary.
Post by Steve Jelf » Sat Jan 14, 2023 10:11 am
Yes, only on the steel parts. Never on the insulator.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Sat Jan 14, 2023 10:39 am
How do you clean old staining off of the porcelain?
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sat Jan 14, 2023 11:05 am
Barkeeper's Friend
Get a horse !
Post by Original Smith » Sat Jan 14, 2023 12:02 pm
The question is, are the copper asbestos gaskets available? Has a substitute been found for the asbestos, and if so are they available?
Post by Steve Jelf » Sat Jan 14, 2023 12:42 pm
The link Steve Hughes and I posted shows the substitute I use. It's what I use because I've never found anything exactly like the originals.
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Sat Jan 14, 2023 1:36 pm
Post by TXGOAT2 » Sat Jan 14, 2023 1:47 pm
Nice radio. What brand is it?
su8pack1
Last Name: Kelly
Post by su8pack1 » Sat Jan 14, 2023 8:12 pm
Carlton.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Jan 14, 2023 9:44 pm
Just soak them in washing ammonia.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Sun Jan 15, 2023 9:59 pm
I tried putting a more modern 1 piece small engine spark plug in a ultra sonic cleaner,that did not work well,it apparently broke the adhesive loose or whatever keeps the porcelain tight in the metal..
Last Name: House
Post by George House » Mon Jan 16, 2023 6:45 am
Steve: many thanks for posting that treatise on Champion spark plugs and the differences therein. Especially the years of their introduction. I have 2 Folgers coffee cans full of ‘em so I’m going to sort out the ones I can dismantle and polish the brass tops of those I can’t 😁
