Replaced my spindle bushings today
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Sun Jan 15, 2023 7:29 pm
This was quite the accomplishment for me. I haven't reamed or shaved metal for 30+ years and then it was under the watchful eye of my father. To put the bottom-line up front, here are before and after videos of the play in my driver's side spindle...
Before: https://photos.app.goo.gl/7Bhf4ptnmuxV91Fv6
After: https://photos.app.goo.gl/8zfFNnHhXbTLPniEA
Here is how I went about it...
I acquired these specialty tools:
3/8 " threaded rod, 4 washers, 2 nuts from my local hardware store - I would have preferred to use a 7/16" threaded rod, but they were out of stock
Split end spindle bushing driver - Langs
Spindle bolt reamer alignment tool - Langs
Spindle bolt reamer - Langs
Bushing face cutter - Snyders
Removed the wheel...
Pulled the spindle and inspected the bushings...
Used the bushing driver to force the bushings out. This was easier than I expected, although I did have to push a screwdriver into the spindle and bushing driver in order to widen it enough to catch the bushing. (photo) Then I used a block of wood to hammer the bushing driver.
Old vs. new bushings...
Arbs
Last Name: A
Re: Replaced my spindle bushings today
Post by Arbs » Sun Jan 15, 2023 7:50 pm
Used the threaded rod with washers to force the bottom bushing into the spindle, the impact driver was set to low, and I took breaks so nothing got too hot...
I then used the reamer, alignment tool and cutting oil to gently ream the bottom bushing. The alignment tool was placed in the top of the spindle.
The reamer slid through the alignment tool, into the spindle body and into the bottom bushing. (photo) The reaming required very light pressure and even, clockwise turning. The top bushing was then forced into the spindle with the threaded rod using the same technique as before.
I reamed the top bushing, using the bottom bushing as a guide.
Next I broke out the cutter and put it on my 1978 drill press. I took two measurements, one of the gap between the spindle arms on the axle and the other was the spindle with the new bushings installed. Don't use these measurements to shave the bushings to size, just use them to know when your bushings are getting close to the right size. Instead, I shaved a little, and tested the fit multiple times. I alternated shaving the top and bottom bushings. From what I have read, you should aim for a snug fit between the spindle and the axle.
After a few iterations of shave and test fit, I got it just the right size. I tightened everything down and the spindle moves freely without any play in unwanted directions.
I'm very happy with the results and I'm surprised how smoothly this went. With the driver's side done and the learning curve behind me, I had the passenger side done in about 30 minutes.
For more history on this project, check out this thread.
Post by speedytinc » Sun Jan 15, 2023 7:54 pm
Good job with minimal equipment.
Post by Allan » Sun Jan 15, 2023 9:05 pm
Don't chuck out the old bushes. They make ideal tie rod end bushes when bored to the correct size, You can even leave part of the top flange on them to ac as a thrust surface to take the weight of the rod at the yoke ends.
VinTin23
First Name: Marty
Last Name: Ray
* REQUIRED* Type and Year of Model Ts owned: 1916 Runabout, 1922 Roadster
Post by VinTin23 » Mon Jan 16, 2023 7:54 am
Well Done! Nice little Tech Thread.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Mon Jan 16, 2023 1:26 pm
I only face the bottom bushing
Arbs
Last Name: A
Post by Arbs » Mon Jan 16, 2023 9:50 pm
Great idea. Thanks Allan.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Tue Jan 17, 2023 1:48 am
Nice job Dan, you are going to end up with a 2023 T touring.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Tue Jan 17, 2023 4:29 pm
Nice thread. This is perfect for the "How-to" Should be moved or copied to the section that has maintenace tips.
Post by TRDxB2 » Tue Jan 17, 2023 5:30 pm
[/quote
Two goo ideas!
But since the Forum doesn't have a dedicated section for "Maintenance Tips" they are where they are - Google
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Jan 18, 2023 8:32 am
Bob,
I faced my top bushings but only to where they were flat and true. I did not trust the flatness of my press when I installed new bushings. Then I faced the bottom bushings for fit to the axle.
Mopar_man
Last Name: Govoni
Post by Mopar_man » Wed Jan 18, 2023 10:42 am
[/quote
Two goo ideas!
Bummer... :? :? Maybe we should?
Post by Scott_Conger » Wed Jan 18, 2023 10:54 am
it exists; just not on this website
https://www.youtube.com/@modelt-tips6985/playlists
Post by Jerry VanOoteghem » Wed Jan 18, 2023 11:10 am
That's because you stepped up and acquired the right tools for the job. They're not cheap and while there may be alternative methods, good tools always pay you back with a good end product. Kudos to you for that alone! Nice work!
Arbs
Last Name: A
Post by Arbs » Thu Jan 19, 2023 10:33 am
I know right... Your comment made me chuckle a few times already. Now every time I put a new part on, I'll be thinking of this.
