4 Bolt Hub identification
tselliott
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Post by tselliott » Sat Jan 21, 2023 10:22 pm
Does anybody recognize these hubs? They take the same bearings as a Model T front hub. The one on the right was actually machined for a AC Speedometer gear, although it was brazed on. Model T hub caps fit on them also. They have a ring that is used on the outside. I believe the wheel would be clamped between the hub and outer ring. I’m not sure what type of wheel, disc or wire would go on them. They have a number cast into them, 03392 maybe.
Any help identifying them would be appreciated.
Thanks,
Scott
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: 4 Bolt Hub identification
Post by t-time » Sat Jan 21, 2023 11:13 pm
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Jan 22, 2023 12:35 am
Post by Allan » Sun Jan 22, 2023 6:36 am
Some Chevs and Essex cars shared the same fine thread for the hubcaps.
