13T - Speedster with Rajo head
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Sun Jan 29, 2023 12:48 pm
Here’s a few pics of a 13 Speedster at the Savoy Auto Museum. I’ve seen the Rajo head a few times. Has anyone run a T with a Rajo head? What kind of performance differences are associated once one is installed? Curious about the specs of the impact it has.
Darin
kelly mt
Last Name: Kelly
Re: 13T - Speederster with Rajo head
Post by kelly mt » Sun Jan 29, 2023 1:04 pm
Do you have a photo of the spare tire mount? Need to build one for my speedster, looking for ideas.
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sun Jan 29, 2023 1:11 pm
This is the only pic I have of the spare tire. Don’t know if it’ll give you enough information.
Post by Rich Eagle » Sun Jan 29, 2023 1:41 pm
Hi Darin. This is the rack I made for my Speedster years ago. It's a piece of flat bar curved to fit the rim. Two angles are bolted to the top of the frame and one ear bent to bolt to the back of the rear cross member. Another piece of angle holds the license plate. I just welded bolts for the lug plates.
If I were to build one today, I would make it riveted construction rather than welding to look more authentic.
Just one idea.
kelly mt
Last Name: Kelly
Post by kelly mt » Sun Jan 29, 2023 6:39 pm
Thanks guys.
DaveBarker
Last Name: Barker
Re: 13T - Speedster with Rajo head
Post by DaveBarker » Fri Feb 03, 2023 10:15 am
Darin - I run a Rajo Model 30 head on my 1919 speedster. Also runs with no magneto, Texas T distributor, and a Stromberg RF carb. I've had it up to 65 mph with throttle to spare.
If you do a Google search on "rajo mtfca forum" you'll get a wealth of information on Rajo heads and the experiences that folks have had with them. I attached a PDF with some great information on several different overheads that were made for Model Ts.
Model T OHV Heads.pdf
(3.83 MiB) Downloaded 72 times
