Drop front axle tie rod & drag link issue
Roger Byrne
Topic author - Posts: 76
- First Name: Roger
- Last Name: Byrne
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
Has any one done a speedster front suspension using a 2" drop front axle, with the early style perches, a double wishbone (above and below the axle) mounted to the engine pan (not on the outside of the frame), reverse eye spring and 26-27 spindles? If so, how did you set-up the tie rod and drag link?
Preserving Mechanical History for Future Generations since 1965
