Magneto coil wrap?
Magneto coil wrap?
Post by Mark Gregush » Fri Feb 03, 2023 2:11 pm
Was the magneto coil wrap cotton or linen? Has anyone tried wrapping their windings with 100% lite weight cotton twill?
Comes in 1/2" too.
https://www.twilltape.com/lightweight-1 ... yard-roll/
Re: Magneto coil wrap?
Post by Scott_Conger » Fri Feb 03, 2023 2:34 pm
depends on if it was a formal wrap or just a family event
:lol:
Post by Mark Gregush » Fri Feb 03, 2023 2:47 pm
Scott..OK that was a good one! Thanks for the :lol:
jab35
Last Name: Bartsch
Post by jab35 » Fri Feb 03, 2023 3:33 pm
Mark: I talked with Mark Fleischaker (Total Re-coil) shortly before he passed away and he told me Ford used 1/2" Cotton Twill and that's what he used. jb
Post by Mark Gregush » Fri Feb 03, 2023 3:50 pm
Fantastic! That should drop the cost considerably. Once the varnish is on, should last as long as the original did. Now the really big discission, do I want black or white?
https://www.twilltape.com/1-2-2/
Post by Scott_Conger » Fri Feb 03, 2023 3:59 pm
Mark I couldn't help myself...
I've never wrapped mag coils but have done a bunch of starter coils and my go-to was cotton twill and then impregnated in polyurethane. They come out beautifully. The way the tape is woven you can get a really nice "lay" with no wrinkles and tight wraps if you are careful.
I switched to black tape as soon as I proofed my process:
Post by Norman Kling » Fri Feb 03, 2023 4:18 pm
I used fiberglass tape from an electronics store and after assembling everything, I coated everything with boat resin from a local marina. I have two of the ones I rewound in two of my Model T's for about 20 years so far no problems.
I followed the instructions in the booklet "Electrical System" published by the club.
Post by Mark Gregush » Fri Feb 03, 2023 5:37 pm
I will still use the self stick fiberglass between the wraps. Going to do my 1/4" one first. I can buy the 1/4" off the shelf. When I am ready to do the 3/16" would make a slitter to size the tape.
Post by Scott_Conger » Fri Feb 03, 2023 5:52 pm
One thing I would point out is that with the cotton twill, you can bias the tape one way or the other and it will remain perfectly flat against the project, when pulled tight. If you are using any other tape which will kink or buckle when tugged sideways or other direction, you'd want to avoid that.
I've never used fiberglass tape in this fashion but would suspect that it is very unfriendly when tugged hither and yon during the wrapping process.
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Sat Feb 04, 2023 10:26 am
This is what I used back when I was wrapping some, I decided it was much easier to let someone else do it. I put one I wrapped in the 23 I’m building now.
I have several rolls left if anyone is interested.
jab35
Last Name: Bartsch
Post by jab35 » Sat Feb 04, 2023 10:50 am
Mark, I'd use white, I doubt the black dye is conductive, but using pure white cotton eliminates that possibility. FWIW, Glyptal 1202 insulating varnish (clear) is a good product for sealing/insulating the mag ring assembly.
Post by Steve Jelf » Sat Feb 04, 2023 11:25 am
The fiberglass tape I used didn't seem terribly unfriendly.
I expect it will last longer than cotton.
Post by Scott_Conger » Sat Feb 04, 2023 11:32 am
cotton lasted 60+ years in starters, generators and field coils, so I'm planning on mine outlasting me. Considering that everything gets coated, if it deteriorates any sooner, something went wrong with the process.
Post by Steve Jelf » Sat Feb 04, 2023 11:46 am
Yep. I don't expect I'll be around long enough to know how well my coil ring holds up.
Post by Mark Gregush » Sat Feb 04, 2023 11:55 am
Ordered the white and plan on sealing with the Glyptal varnish. Darn, Snyders is out of stock on the insulators, so guess I will have to make my own!
jab35
Last Name: Bartsch
Post by jab35 » Sun Feb 05, 2023 10:28 am
Have fun, Mark. I would not worry about the longevity of cotton twill if the assembled unit is fully saturated with the insulating varnish. The wicking action of the twill draws varnish into the wrapped coils. Baking the air-dried assembly @ 200F for two hours enhances the properties of the cured varnish. Quoted from Glyptal 1202 specifications: "Although primarily an air-drying varnish, the oil, moisture, acid, and salt water resistance are greatly improved by baking. GLYPTAL 1202 has excellent adhesion to most materials."
One tip I'd offer regarding the Fishpaper washers that go behind the wrapped coils against the mag ring frame. Instead of making the outer shape a uniform oval matching the outside geometry of the coil, make that profile more pear-shaped, so you have extended the insulation to the area where the coil leads are crimped and soldered, that way you have insulation between the ring frame the soldered joints in the copper. I know Ford didn't do the and most rebuilders don't bother, but Total-Recoil did and I think it's insurance that costs nothing. I used 0.020" thick Fish paper that I obtained from MM-Carr. Best, jb
Last Name: Hatch
Post by Dan Hatch » Sun Feb 05, 2023 11:55 am
If you will visit a local motor shop they can hook you up with the correct tape and if you ask nice will dip your coil for price.
When I was rebuilding coils it cost me $10,00 a coil for dip and bake. That was on the 80’s. I still find my coils in engines sent to me for rebuilding.
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
Post by hah » Sun Feb 05, 2023 2:01 pm
Light-weight or heavy duty cotton twill tape? Any particular size? ie: 1/4, 3/16 or maybe 1/2?
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Mon Feb 06, 2023 5:33 am
I use 10mm cotton strips 130 cm long for the single oval and 140cm long for the others.
After assembling and testing the loop, it ge three coats of polyester coating.
Work fine for me.
Andre
Belgium
Post by Mark Gregush » Mon Feb 06, 2023 7:18 am
Thanks everyone for the posts and suggestions. Will see how it goes now. :)
