Ford part I.D.
FATMAN
Topic author - Posts: 1697
- First Name: ROBERT
- Last Name: BERGSTADT
Ford part I.D.
I found a few of these in a box has a Ford script part number looks like T 1125 B
Any idea what this is,
Thank you, Bob
Thank you, Bob
Bruce Compton
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: Ford part I.D.
Might be a hinge part for a tailgate............wild guess.
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Re: Ford part I.D.
I found a listing for T 1125 B Shown as a TT frame bracket in the parts books. Lang's even has them for sale. BUT, the bracket doesn't look anything like the photo you posted. It may be a tractor part? I have not found much more.
Good Luck
Good Luck
- Last Name: Tannehill
- Board Member Since: 2002
Re: Ford part I.D.
Radiator support rod holder who’d thunk
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Ford part I.D.
It’s a radiator support rod bracket.
TrentB
- First Name: Trent
- Last Name: Boggess
Re: Ford part I.D.
I agree with Adam.
This piece is riveted to the top tank of black era radiators and protrudes through the rear wall of the tank. It is threaded for the radiator stay rod.
Respectfully Submitted,
Trent Boggess
Trent Boggess
Adam
- First Name: Adam
Re: Ford part I.D.
Part # 4000 , Factory # 1125b
Re: Ford part I.D.
Radiator suppert bracket foe me too. These are cast iron, and need thorough tinning when installing them. The threads can pull in them if the locknut is omitted when fitting the rod.
