Moore trans measurements
warwick_preval
Topic author - Posts: 27
- First Name: warwick
- Last Name: preval
- * REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
- Board Member Since: 2014
Hello all, can someone tell me the exact measurements for cutting down a drive shaft & drive shaft housing for a Moore under drive accessory trans for a T cheers Warwick.
Re: Moore trans measurements
Warwick, there is wriggle room when cutting the tube, as the receiver on the front of the gearbox is 4-5" long. The tube can be clanmped in the receiver to make it fit when in place. When I found mine, the tube and the driveshaft were already cut, having been previously fitted. I cannot help with the driveshaft length, except to say if you fit the tube to the gearbox, hook it up at the ball joint on the trans, you will have a starting point to measure up how long the shaft needs to be.
warwick_preval
- Last Name: preval
Hello & Thanks Alan,there seemed to be a lot of wear in the clamp side of the casting where the tube buts up against it & i wanted to make sure the tube was the right length. I borrowed a shaft from Andrew Web & i wanted to be sure of the sizes before i cut anything as i only have one of each
cheers Warwick.
cheers Warwick.
