13 - 15 bulb horn
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
13 - 15 bulb horn
Post by Craig E. Luton » Thu Feb 23, 2023 10:19 pm
I am told that there is a difference between the 1913, 1914 and 15 bulb horns. Can anyone explain to me just what that difference is? I do know that there is different mounting brackets used on the bulb horns of that era (the cast bracket that bolts the horn to the wood dash); some are oval and others are round in shape. What is correct for 1913 and/or 1914?
Thank you in advance
Craig
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: 13 - 15 bulb horn
Post by got10carz » Fri Feb 24, 2023 8:50 am
This is what I believe, 13 round, 14 oval, 15 oval sort of with scallops.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Feb 24, 2023 11:51 am
Steve is correct I believe.
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Fri Feb 24, 2023 6:00 pm
That round base was used on latter 12 also, if not mistaken.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Sat Feb 25, 2023 11:36 pm
My 13 horn
Post by Rich Eagle » Sun Feb 26, 2023 5:31 am
There is some very good information at the end of this thread:
http://www.mtfca.com/discus/messages/59 ... 1483212466
Post by TRDxB2 » Sun Feb 26, 2023 12:37 pm
Rich's referenced link is golden (brass) just some pics from it
