Mounting Aermore whistle
Reno Speedster
Topic author - Posts: 636
- First Name: Morgan
- Last Name: Blanchard
For the folks running Aermore whistles, do you point the whistle pipes forward? I can’t find pictures but that seems to make the most sense.
modeltspaz
- First Name: Mike
- Last Name: Spaziano
Re: Mounting Aermore whistle
The Aermore whistle on my car was on it when I bought the car. It's pointed towards the rear.
Mike.
Mike.
Didn't you get the multiple photos I sent you Morgan ?
jiminbartow
- Last Name: Patrick
Here are two photos. It looks like it can be installed either way. Your choice. Jim Patrick
Reno Speedster
Steve, no I didn’t get them.
Morgan
Morgan
I just re-sent them - let me know if you get them - both on the Centerdoor & the Touring.
- Last Name: Hjortnaes
I think it depends on how your valve is configured. I suppose you could hook it up so it blows all the time unless you step on the pedal.
Would not matter which way the valve was pointed, the valve would be closed off to the whistle unless actually pulled open.
For some of us that actually drive or have driven in the rain, pointing to the front might help keep the water out of the tubes and might produce a less gurgling sound!
modeltbarn
- First Name: Gary
- Last Name: London
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring
I've mounted them both ways, and was happiest with the tubes forward.
