Top Saddle Support Arms
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Sun Mar 19, 2023 9:41 pm
I finally found top sockets for my 24 roadster. My new crisis is that I ordered top saddle support arms https://www.modeltford.com/item/3858B.aspx
The reproduced arms have an 11/16 fine thread. They would not screw in and when I looked into it, the area where mine screw into are either 1/2 or 5/8 coarse. (I dont remember which)
ANYWAY. Does anyone have information on the thread differences. Are the coarse thread arms available??
Thanks.
Last Name: Humble
Board Member Since: 2006
Re: Top Saddle Support Arms
Post by Humblej » Mon Mar 20, 2023 8:03 am
Tom, I am in the same boat.
ADDED 4/4 23:
[Correction, although a 5/8 bolt will screw into the hole it will slip when tightening, so the hole is larger than 5/8.]
Looking at period and factory photos it appears the top saddles and arms were not installed at the factory and a rubber plug was covering the hole in the body. If the arms and saddles were supplied as a loose part or in a bundle with the tool kit, is anyone's guess, I have not found any documentation either way. One factory photo shows the 15th million T getting its arms and saddles installed at the end of the line.
tom_strickling
Post by tom_strickling » Mon Mar 20, 2023 8:09 am
Thanks again Jeff.
I am going to see if the 11?16 could be turned into 5/8 by my machinist. I am sure he will think of something. I will let you know.
Post by Mark Gregush » Tue Mar 21, 2023 3:57 am
Posted new information after doing some checking.
tom_strickling
Post by tom_strickling » Tue Mar 21, 2023 8:43 am
The description in their catalog says 11/16.
I just assumed they would work I guess
Post by Mark Gregush » Tue Mar 21, 2023 2:48 pm
All 4 that I have, 2 fender supports and 2 for my roadster top rest, are 16 TPI. Mine measure about between .665 and .675 on the outside of the thread.
There is a good possibility that the ones you have are correct and there are issues with the holes you are trying to screw into. Don't know, can't see what you are working with.
Added more information in my post down below. There is an 11/16 X 16 TPI tap made.
Post by Scott_Conger » Tue Mar 21, 2023 3:31 pm
tap drill for 3/4" thread: .656 (coarse), 21/32 (fine)
FWIW, while not common, 11/16 diameter can be found in 11,12, 16, 20, 24, 28, 32 TPI (just in American sizes...a couple more in British sizes)
11/16 might not be found in standard tap/die sets, but that only means the set is incomplete due to low use of that size
Post by Mark Gregush » Tue Mar 21, 2023 4:29 pm
I just looked on line and found one on MacMaster Carr:
https://www.mcmaster.com/taps/thread-size~11-16-16/
Yes, there are lots of other sizes, not all are listed on most tap/die/drill charts.
