Hotter Spark Plug
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Hotter Spark Plug
Post by jaybee47 » Sun Mar 12, 2023 10:40 am
Which is of the three spark plug brands offered by T parts suppliers is hotter: the Champion, Motorcraft or Autolite? Is there a spark plug (1/2" tapered thread or 14MM thread w/adapter) that is hotter than any of these?
Re: Hotter Spark Plug
Post by TXGOAT2 » Sun Mar 12, 2023 10:47 am
Manufacturers' websites may have information on heat ranges.
In most cases, plugs of various brands and types are available in several heat ranges.
In most cases, the plug recommended by the engine maker, or that plug's equivalent, gives the best results in general service.
Post by Mark Gregush » Sun Mar 12, 2023 11:35 am
Going with the 14mm plugs; Sure there are different temperature ranges, the different brands should have that information on their pages. One thing that I have found, if going with the 14mm plugs and running on magneto, get the non-resister type, they don't have an "R" in the number. I have found the resistors don't seem to play well with the magneto voltage that is all over the place.
Post by TXGOAT2 » Sun Mar 12, 2023 11:40 am
I'd stay away from resistor plugs or any kind of "suppression" plug wire on a stock T system. I tried using a portable radio in and around my T with the engine running. To my surprise, I was able to listen to most AM stations with little interference. FM worked great. The 40 year old AM-FM-Shortwave portable radio was running on internal batteries, and not connected to the T system.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sun Mar 12, 2023 11:41 am
Some people use a hotter plug than recommended if the engine burns excessive oil.
Art Mirtes
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Sun Nov 19, 2023 4:09 pm
What is the recommended 14mm plug? Brand/part number. Running a distributor on this one.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Nov 19, 2023 4:14 pm
Compression ratios too have a lot to do with heat ranges of the spark plug. A cold range plug does not operate the same with higher compressions.
Just Sayin'
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sun Nov 19, 2023 4:29 pm
My one and only experience with 14mm spark plugs was very disappointing. I used the hottest I could get. Top speed was reduced and the exhaust ran red. Maybe it was because the electrodes don't extend into the combustion chamber to the same extent as the proper plugs.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Nov 19, 2023 4:54 pm
Yes John it does as the adapters with the plugs actually lowered the compression just by a little and cause a heat shunt. Second.., your manifold getting red is another byproduct of the plug gap/timing/or mixture not being in sync with the change. You have to use a long reach threaded plug with adapters to maximize the good effects. The adapters with the shorter plugs act more like an "anti-foul" adapter.
