Interesting Ford test report
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sun Mar 12, 2023 9:46 pm
Interesting Ford test report showing the improved oil flow between old and new oil pipe.
Re: Interesting Ford test report
Post by TXGOAT2 » Sun Mar 12, 2023 9:49 pm
That's a very low rate, assuming a warmed-up engine and clean, 20W oil.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Sun Mar 12, 2023 9:58 pm
This is the oil pipe out of the very first model T’s. The later ones ere a vast improvement.
Last Name: House
Post by George House » Mon Mar 13, 2023 8:46 am
‘Vast Improvement’... I should say !! 6-7 times more volume. Good information Kim. Thanks 🤔
Post by John kuehn » Mon Mar 13, 2023 10:28 am
WOW the first oil flow pipes weren’t much but maybe a little! The later were much better. When 09 T engines are rebuilt does a purist put that back in or use a later improved line. I’m not trying to be a smart guy but it does make me wonder! Thanks for the education. Much appreciated.
Post by Original Smith » Mon Mar 13, 2023 10:51 am
Too bad there isn't a date on that report. I think from the service bulletins, the new design came out in 1924?
Post by Jerry VanOoteghem » Mon Mar 13, 2023 10:54 am
Thanks Kim! What a great document. I'll bet those lab guys would have never dreamt that over 100 years later, we'd be looking at their report, and they could not even begin to conceive of the means by which we're viewing it!
Post by John kuehn » Mon Mar 13, 2023 11:31 am
Is there any evidence that the very early oil line had the mounting ear with the single hole to secure the oil line or is the picture shown the oil line without the mounting bracket. If the very early line didn’t have the mounting bracket how was it secured.
Post by TXGOAT2 » Mon Mar 13, 2023 11:35 am
Did the early pistons have oil return holes in the lower ring groove? It may be that oil control issues precluded higher oil delivery rates.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Mon Mar 13, 2023 3:13 pm
The oil tube on the very first 1909 cars was held in place by a steel strap wrapped around the tube and fastened by a mag ring bolt.
The first 1909 cars used a steel transmission cover had a sheet metal funnel so the flywheel would sling oil into the funnel to fill the oil tube I pictured.
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Mon Mar 13, 2023 6:55 pm
Pat, the early pistons (4.89 lbs each) didn’t have any oil return holes.I also pictured an early 1909 rod. Not the step in the rod cap and corresponding rod end and the built in rod dipper.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Tue Mar 14, 2023 10:01 am
Kim, I really appreciate seeing these photos of the earliest parts ! Very interesting to see the evolution. Thank you !
Get a horse !
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Tue Mar 14, 2023 2:58 pm
Thanks Kim for posting!! That's an amazing difference. My '12 engine had the smaller funnel listed as "Present Standard Oil Pipe" I never had a doubt about which one to use during a rebuild after seeing the Large later style!! Now it's a nice show N tell. I also installed an external line and welded into the alum HH the little angle diverter like the later ones have cast there. Would be an interesting comparison of the "high flow" outside oil line volumes.
1912 Torpedo Roadster
