Is it 110 or 240 volt
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Sun Mar 26, 2023 9:44 am
From a friend I got a Octopus Growler ,he is made in England .
Here in the Netherlands we have 240 Volt AC .
So I like to know or this growler is 110 or 220 [240] Volt .
Thanks for your answer .
Toon
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: Is it 110 or 240 volt
Post by got10carz » Sun Mar 26, 2023 10:35 am
I might start by pulling out a light bulb and search its voltage.
Post by Mark Gregush » Sun Mar 26, 2023 10:40 am
Not an expert but seeing the type of bulbs installed, I would think it 240. North America made unit would have screw in bulbs. You could take one of the bulbs out and see what is stamped on it.
Cap
First Name: Cap
Last Name: Weir
* REQUIRED* Type and Year of Model Ts owned: 24 & 25 C Cab
Post by Cap » Sun Mar 26, 2023 10:57 am
To Clarify...
Check the Voltage of the Red Bulb..
I'm thinking the two clear bulbs underneath are part of a Current Limiting Circuit.
Cap
Last Name: Juhl
Post by Oldav8tor » Sun Mar 26, 2023 1:05 pm
Normal line voltage in the UK is 230 volts 50 cycle.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Mar 26, 2023 1:34 pm
Hi Anthonie,
I once found a article about uning a bridge rectifier on the power side to turn a growler into a magnatizer for mag magnets?
Post by TRDxB2 » Sun Mar 26, 2023 1:43 pm
Just in case you don't have it. Found on the internet - operating instructions. Looks like its plugged into another device . I would also suggest checking the bulb for voltage
part 1
https://www.vintage-radio.net/forum/att ... 1624650478
part 2
I'm think that the growler is hooked up to a main device for power leaving it up to you
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sun Mar 26, 2023 7:27 pm
Seeing that it's British, uses B22 based bayonet light bulbs, and has the European colour code for the mains cable, it can be assumed to be 240V.
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
Post by hah » Sun Mar 26, 2023 8:55 pm
Type of plug??
Post by TXGOAT2 » Sun Mar 26, 2023 10:26 pm
Not enough information. The manual pics show an ignition and generator test machine. The growler appears to be a separate unit with its own power supply. I don't believe the test prods shown in the illustration are meant to be connected to any power supply.
Post by TXGOAT2 » Sun Mar 26, 2023 10:38 pm
See the Wikipedia article on growlers. It explains their basic function and how they're used. It has a picture of a growler similar to the one under discussion. If you look carefully at the picture, the label indicates that the unit pictured in the article is for 120 volt AC. I'd guess that the Octopus growler is intended for 240 volt 50 cycle. The basic growler is a fairly simple device. The Octopus growler appears to have more than one function. It ought to have an on-off switch and some evidence of where the power supply is , or was, connected. The test lead function probably would not need to work for the growler function to work.
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Mon Mar 27, 2023 5:01 am
Hey Toon, engels en al wat ouder dus 110V de bajonet fitting van t lampje is ook typisch engels voor 110V, hier aan onze kant van het water en in de USA gebruikten we al lang schroef fittingen voor verlichting op iets anders dan laagspanning (12/24V)
Mooie vondst, je kunt m gebruiken met een "reistrafo" voor 220 naar 110v.
Leo van Stirum, Netherlands
Post by TRDxB2 » Mon Mar 27, 2023 12:22 pm
Check your bulb from part 2 of the instructions link
Given that the product was manufactured by The Armature Manufacturing CO., Ltd.. Middleton Road, Oldham, Engling, UK
I assume you got this in the UK. The OK has been 230v as is Europe. The main tester is is 230v The growler a continuity tester has a bulb < evidence 99.99999% 230v
Impressive looking machine
octy 1.png (763.55 KiB) Viewed 2557 times
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Mon Mar 27, 2023 4:26 pm
ABoer
Last Name: Boer
Post by ABoer » Thu Mar 30, 2023 11:05 am
Thanks for all the information !!!!!
Toon
