Scripted castle nut
Billy Vrana
Topic author - Posts: 108
- First Name: Billy
- Last Name: Vrana
- * REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
Scripted castle nut
Ever notice the script here? I've been working on painting my tt frame. I pulled the rear leaf springs to inspect and sandblast and found this nut on one of the bolts. Not sure it on the bolt going through the spring on on the u bolt. Could it have been part of final inspection or am I over thinking this?
Re: Scripted castle nut
Like many parts on the Ford, beginning in 1919 Ford strived to mark parts to distance from 'aftermarket' parts, that may not do the job. Even those simple parts like castle nuts got with the program!
Darn you Dan. Do you realise I now have two gallons of castle nuts to clean and inspect.
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
If you look at the spring perch nuts, they’re scripted too.
Brad
Brad
