1926 Model TT Height
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Fri Apr 07, 2023 2:52 pm
We are not moving, but will need to expand the garage! I'm hoping someday to get a '26 TT that needs to be restored (it's painted, but not assembled). In trying to figure out the dimensions, I have that they are approximately 65" wide and 155" long. What is the height of one? It has the enclosed cab.
rwephill
Last Name: Evans
* REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab
Re: 1926 Model TT Height
Post by rwephill » Fri Apr 07, 2023 3:25 pm
Sounds like your TT project is at about the same state as mine. Finishing the cab and getting ready to put it back up on the frame. I have a C-Cab, but I know that both factory cabs are quite tall. Though I cannot answer your height question exactly, I can say that they will not fit in a standard 7' high garage opening. We need garage doors that have one additional panel for height clearance.
Good luck with the completion of your truck.
“You don’t have to go fast… you just have to go.”
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Fri Apr 07, 2023 5:36 pm
Both my TT’s with steel closed cabs are 7’2”. One is on 23’s front and rear, the other 21” front and 20” rears.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Sat Apr 08, 2023 1:56 am
Mine is 84" to the high point at the back of the cab.
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Post by FreighTer Jim » Sat Apr 08, 2023 3:47 am
Scott,
Every Model T is different.
Every Model TT is different.
Make your door as tall as possible.
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Sat Apr 08, 2023 9:20 am
Just able to squeeze this guy under my carport.
Jacob Mangold
First Name: Jacob
Last Name: Mangold
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 TT, 1928 A Coupe
Board Member Since: 2023
Post by Jacob Mangold » Sat Apr 08, 2023 6:41 pm
My ‘24 TT is just above 7 feet tall. Probably 7 foot 1 inch. Mine is a standard cab, not a c cab. They are pretty darn tall. :lol:
26modeltt
First Name: Jack
Last Name: Leonhardt
* REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
Post by 26modeltt » Sat Apr 15, 2023 2:59 pm
Our '26 Closed Cab TT w/ 650-20 rear tires and 450-21 front tires has a height of 85 3/4"
