I just got this with a load of Model T Ford parts but it is not Model T Ford
larger threaded area 3/4" with coarse threads the tie rod bolt is smaller than a Model T about 7/16? also has a large taper for the ball stud, can not make out the numbers? any ideas, Bob
Can anyone identify this Early tie rod yoke large with coarse threads larger than Model T Ford
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
Re: Can anyone identify this Early tie rod yoke large with coarse threads larger than Model T Ford
Bob, Try checking a Fordson parts list. I don’t know for sure but it looks like what I have seen on a Fordson from the 1920’s.
