New floor and under seat pannel
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Fri Apr 28, 2023 9:13 pm
The front floor boards in my 22 were old home made replacements and made out of oak. They were dried out and cracked and the “fingers” between the pedals kept breaking off. So I whipped up some new ones. They are not perfect, but they are much better than what I had and they go well with the rear floorboard I made a while back.
While I was at it, I decided to make a panel to go under the seat. You will notice that it’s not like the ones Ford made, but my body framing is a bit different (old restoration) and the original type won’t work (there is nothing to support the front cross piece). I bought a metal one, but it didn’t fit right either. So I made one up that looks pretty good and does the job. If I ever rebuild the body I will change the framing and do it right.
Re: New floor and under seat pannel
Post by Norman Kling » Fri Apr 28, 2023 10:01 pm
Looks good and will be covered by floor mat and the seat cushion. I agree with you.
Post by Allan » Sat Apr 29, 2023 4:13 am
Norman, I stop the "fingers" between the pedals breaking off by drilling deep holes in them and inserting a wooden dowel in the hole. It works a treat and is not noticeable at all
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Sat Apr 29, 2023 8:30 am
Nice work.
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Sat Apr 29, 2023 8:53 pm
Nice job, looks good.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sat Apr 29, 2023 11:48 pm
And painted…. The reinforcing plates will go on tomorrow.
