Information Wanted
Topic author - Posts: 5486
Information Wanted
I'm attempting to assist a local upholstery gal locate any photos of a 1909 Towncar interior - front , back & top both inside & out for a friend's recently acquired project. I've done some searching on the web but not much out there - anyone here might have any documentation to share ?
Re: Information Wanted
You may have seen these already.
Mecum: https://res.cloudinary.com/mecum/image/ ... 6955_7.jpg?
Probably not correct: https://th.bing.com/th/id/R.aaf448b0c07 ... ImgRaw&r=0
/???https://photos.classiccars.com/cc-temp/ ... ar-std.jpg
No, I had not - thanks Rich !
Scroll down this link Craig Beek has 1910 Town cars and you may catch a look
https://www.mtfca.com/discus/messages/2 ... 1355842280
Thanks Frank !
I’m out of town now might be able to take some closeups early in the week.
Luxford
- First Name: Peter
- Last Name: Kable
I think the interior of 1909 to 1912 are similar if not the same, the bodies were supplied by different companies and vary in design but the upholstery is virtually the same. Both Richard Williams TC ( the red & black TC on the Vintage Ford Cover) and Paul Antonucci's a green TC now owner by someone else have the same type of upholstery. Mine is a direct copy of Paul's interior. The color photo's show my TC the B&W the Williams car. The photo's of Paul's TC are too large to post.
Luxford
- First Name: Peter
- Last Name: Kable
Just did a resize on line, it worked but quality is So So. Here it is.
If you need any more detail info let me know I probably have it.
I thank you kindly Peter ! I attempted to send you an email but was most likely an old address.
Luxford
- First Name: Peter
- Last Name: Kable
Steve, I have just emailed you lets see if works
I didn't get to Craig's yt but here is a photo I took a year ago or so. The buttons are deep into the upholstery - almost on all his carsRajoRacer wrote: ↑Fri Apr 28, 2023 11:44 amI'm attempting to assist a local upholstery gal locate any photos of a 1909 Towncar interior - front , back & top both inside & out for a friend's recently acquired project. I've done some searching on the web but not much out there - anyone here might have any documentation to share ?
