Touring
Re: Touring
Who can spot the Canadian T? (At least 1 anyway)
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: Touring
The 8th pic 15 Touring with a drivers door.
Re: Touring
I would say that the 4th photo is a Canadian car, Jerry. The bracket for the folded down top irons is what they used. It is a good exapmple of a 1923 as it has a low hood and radiator and front fenders without the flair at front. I can't tell for sure but the driver's door should open also.
Maybe I do see a hinge.
- Last Name: House
Re: Touring
What I find interesting is 4 LHD carbide headlamp tourings with no carbide generator or acetylene tank. This is from left side views. Great pics Tom !! Thanks !
Re: Touring
You win Rich! The top saddles, as you mention, plus the oval windows in the top, also the wide windshield stanchions and the little "protectors" on the top edges of the doors.Rich Eagle wrote: ↑Wed May 10, 2023 2:06 pmI would say that the 4th photo is a Canadian car, Jerry. The bracket for the folded down top irons is what they used. It is a good exapmple of a 1923 as it has a low hood and radiator and front fenders without the flair at front. I can't tell for sure but the driver's door should open also.
Re: Touring
Three of the brass cars that would have originally had gas headlamps clearly show the headlamps have been electrified. The gas headlamps originally had the "mirrors" way in the back of the headlamp bucket to reflect and focus the gas flame in front of the mirror forward. The inside of the bucket was dark, and viewed from a side angle generally appears dark. Look at the 17th photo (next to last) of the 1910 touring. Note how dark the inside of the buckets are.George House wrote: ↑Wed May 10, 2023 2:37 pmWhat I find interesting is 4 LHD carbide headlamp tourings with no carbide generator or acetylene tank. This is from left side views. Great pics Tom !! Thanks !
The "electrification" kit included reflectors that held the bulb and mounted right inside directly behind the lens/bezel. This maximized the benefit of the electric bulb (which really wasn't quite as bright as the gas flame!), and also made the reflector readily visible from a side angle.
The fourth car not showing the acetylene source that should be there does not show the headlamps. However, it does show electric sidelamps! So, very likely the headlamps are also electric.
Good eye George H! This is what I like to see. Great photos followed by observations and questions leading to discussion and answers!
Electrifying headlamps became very common after 1912 when Cadillac premiered a practical electrical system for automobiles. I probably have more than fifty (maybe a hundred?) 1912 through 1914 model T era photos clearly showing electrified headlamps.
