Tie Rod FLEX?
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Tie Rod FLEX?
Post by Professor Fate » Sat May 13, 2023 12:27 am
Anyone have or ever see a springy, flexing tie rod?
________________
**FATE**
Re: Tie Rod FLEX?
Post by Jerry VanOoteghem » Sat May 13, 2023 7:32 am
They're hollow, so they're all kinda flexy, to a point. Just how flexible is this one? Under what conditions are you seeing it flex? Beware of thinning from internal rust and/or cracks!
Art M
First Name: Art
Last Name: Mirtes
Re: Tie Rod FLEX?
Post by Art M » Sat May 13, 2023 10:10 pm
What is the wall thickness (thickness) or the inner diameter of the rod. With one of those dimensions and the outer diameter, the expected flex could be established.
Art Mirtes
Professor Fate
Last Name: S
Re: Tie Rod FLEX?
Post by Professor Fate » Sat May 13, 2023 10:19 pm
I need someone to turn the wheel so I can look. As soon as i get assistant we'll know more.I'll have to pull the linkages apart to measure thicknesses.
________________
**FATE**
Last Name: Strange
Re: Tie Rod FLEX?
Post by CudaMan » Sun May 14, 2023 8:22 am
Just looking at the parts, I worry more about the skinny drag link than the tie rod, especially in compression. However, the stock linkage seems up to the job on my and millions of other Model Ts. :)
Re: Tie Rod FLEX?
Post by TXGOAT2 » Sun May 14, 2023 9:49 am
Your tie rod should not be springy. It's probably bent, or has been bent, or is rusty, inside or out, or has been in a fire. I'd look for another one, rather than tempt fate.
A bent or otherwise weakened tie rod may give way if you hit a pot hole.
A straight tie rod is very strong in compression. A bent one is much weaker.
A bent tie rod would probably give the steering a rubbery feel.
